fallguy
Boat Builder
- Joined
- Dec 7, 2016
- Messages
- 8,934
- Reaction score
- 2,091
- Location
- usa
I'm the big guy in the cafeteria and if you pick on Richard, you've picked on me. Plus, 'ask the designer' is such an annoying default.
What in God's name is so hard to understand? I have a gritty personality from the last month of fairing my boat and the last day of sanding was today at 320 grit. I'd say I'm just fine! Except my back is having infrequent spasm that wraps around my chest from the torture board which feels like a heart attack, but isn't. I just double over and go to the ground for a bit. Alcohol seems to actually help a bit.
Crickeys, can't a collective bunch of gents come up with some kind of silly putty and call it good? Crickeys is for Brendan and his all caps shot.
The beam goes into a glass socket that is about 0.125" larger all around, but there is a silencer that goes in two places where two 14" long bolts go through. The bolts are just through the beam and bolted across the socket and a bulkhead. That beam is the seat for the cabin aft half. The bolts are 316, so any salts getting in there bother me. There are 5 other rivnuts also 316 in the beam. Best to keep the water out.
I tape the silencing on with duct tape, but any H2O that gets in would find its was back around into the section and into the crevices around the silencing.
Now that I have polished things here to 60 grit, hope it makes more sense.
This thread could have been closed after the duct seal comment. That stuff is ideal for caulking a two sided bond open crack. It'll go up to like a full inch as well.
I am going to freshwater first. I think. So had no plan to paint the beams. If or when we go salty and we hope to at some point; I would need to alodine a/o paint the beams. Now, all of you guys saying don't bother sealing are going to jump up and down and shout I was right. Please link the video.
Here in Minnesota, water sitting in places freezes and growz. And it busts things, so we do all we can to prevent it from ingress.
A common one is a trim pump. Once the trim pump seal goes; any bit of water gets sucked in and the trim pumps grow inside. So, we just avoid water ingress here like the plague. It is frozen here nearly 6 months of the year. The mean temperature of Lake Superior where I might end up is 39F. Today is late summer and mid lake surface temps are likely in the 40-50 range. The season is short. To complicate things, some places get 10 feet of snow. This is too much for most boat cabin roofs. I suppose I should have asked Richard to design for that, too, eh? Nah.
Rumars-sealing the beam/socket interface only. Duct seal is a good choice. I can keep a chunk onboard and double bag it.
I have to go do some vacuuming now.
I'll share a picture of the boat here in the next month that should be entertaining.
Above pic is prior to hours of sanding today.
