navigation light circuit
Discussion in 'OnBoard Electronics & Controls' started by munthersaif, Mar 29, 2020.
  1. munthersaif
    munthersaif New Member
    hello
    Could any body help me I want to build new navigation light panel with the buzzer to be run when my lamp is burn out..
    did any one have electrical circuit drawings for the system . ?
    What are the requirements of the circuit? If it is just for fun, that is relatively easy. However, for a critical application it will require redundant systems.
  3. munthersaif
    I need it to be install in place of damage one,so it must be same as before witg buzzer when lamp burnt out
  4. Ike
    Ike Senior Member
    What Navlights? is this a combo red/green, single stern light on a pole? More details needed. I have a typical diagram for the combo light and stern/anchor light if this is what you have?
  5. gonzo
    He wants an alarm to sound when one of the lights is burnt. Usually, that is done by using the power side of the light as ground reference. If the bulb burns, it triggers a switch because there is no ground path.
    munthersaif: do you have the part available? It is possible you could get a direct replacement.
  6. munthersaif
    i dont have old part with me, Im looking for circuit even for 1 light no problem then i will improve to all light.
    LKE : please send me what circuit you have
  7. Ike
    Ike Senior Member
    DogCavalry and hoytedow like this.
  8. kapnD
    Likes: 122, Points: 43, Legacy Rep: 40
    kapnD Senior Member
    What if the buzzer fails? Better include a test circuit for that!
    Replace the lights with sealed LED units and forget it.
    BlueBell likes this.
  9. Ike
    Ike Senior Member
    The diagram does not include a circuit for an alarm. Someone smarter than me can, I'm sure, figure out how to do that. I actually drew this to add to my website simply because I needed to determine why my anchor light is not working.
  10. TeddyDiver
    TeddyDiver Gollywobbler
    Five pole relays connected to each nav light positive wires? There should be easier way thou..
    hoytedow and BlueBell like this.
  1. Mat-C
  2. ellawendy
  3. cthippo
  4. Gianf1041
  5. SV_Harbinger
  6. the brain
  7. Manie B
  8. old man
  9. Tim.M
  10. Ike
