Doug Halsey
Senior Member
- Joined
- Feb 7, 2007
- Posts
- 664
- Reaction score
- 232
- Location
- California, USA
I'm not finding any references to magnetism in those references. Is that your own personal nickname for something?
Note: This feature may not be available in some browsers.
<shrug> Just how I internalized the concept way back in the late '80s early '90s when I had the need to work with it. Basically you can only "pull" on a water "element" (however you define it) until it breaks into two elements (i.e. a cavitation bubble forms or a drop separates), but when placed near each other they want to join back up (surface tension). You can model this many ways as the wiki SPH article statesI'm not finding any references to magnetism in those references. Is that your own personal nickname for something?
The Smoothed-Particle Hydrodynamics (SPH) method works by dividing the fluid into a set of discrete moving elements...<snip>
These particles interact through a kernel function with characteristic radius known as the "smoothing length", typically represented in equations by h. This means that the physical quantity of any particle can be obtained by summing the relevant properties of all the particles that lie within the range of the kernel, the latter being used as a weighting function W..... <snip>
Kernel functions commonly used include ..... <snip>
Although the size of the smoothing length can be fixed in both space and time, this does not take advantage of the full power of SPH. By assigning each particle its own smoothing length and allowing it to vary with time, the resolution of a simulation can be made to automatically adapt itself depending on local conditions.....
They aren't (except on a macro scale) and it doesn't....it a model. That on itself does not mean that the answer is useless; just that that is the answer that the model got for for those initial conditions. We can never really know the actual conditions therefore models are always going to be "incorrect". What matters is when I run an actual physical test, the model approximates what happens.@jhardiman - for those of us less mathematically inclined: how are simulation methods like VOF or particle-in-cell verified? I.e. how do we know that the animation represents reality?
I think this is the crux of the matter. A model 'simulation' is not a physical 'test'. The starting conditions cannot be the same, so don't expect the answer to "be real". But a visual simulation could look like a physical interaction and have similar data. There are many model that 'simulate' a drop splash....but they are not a drop splash. Similarly, there are models that can 'simulate' a wake curl at the bow of a ship, and may even give a calculated numerical value for the drag.... but they are not an actual bow wave curl. Those of us who came through our engineering development when we went from log tables and slide rules (mid 1970's) through initial CFD (mid to late 1980's) into modern visualization system (mid to late 2000's) understand the inaccuracies in what is presented. Modern students who google things instead of writing their own code may not fully understand the difference. Hence the issue today with 'deep fakes' ....anything can be 'simulated' and presented as 'truth'.We now see a lot of visually compelling digital simulations of phenomena like waves and water motion, and I wondered if a visual comparison between say a VOF model of waves interacting with a submerged structure, a 'solid' (don't want to say 'physical') model of that structure in wave tank, and say video documentation of a waves crashing around the rpresenative structure in the real world would be a representative example of a 'physical test.' Of course, we can use transducers and sensors and gather additional data beyond what I might term 'visual' observation and comparison. How often is 'it looks the same and here's why' considered adequate?
Annddd.....what did you miss on the phrase 'model"?And wouldn't the wave tank bow wave model the behavior of the bow wave on a full size ship, and be no more or less accurate than a computational simulation, depending on experimental setup of the former vs. the algorithm of the latter?
Not really. Boats and ships get built after the design has been validated by tank tests or computer modelling. It is not so expensive to compare measured vs predicted data.I would assume validating 'model' results against full-scale phenomena or structures is generally quite difficult and prohibitively expensive.
As someone who has done just that several times; the answer is you never get, and should never expect, point-to-point correspondence. That is because you can never replicate the model's input parameters exactly during the experimental data collection. Furthermore, this is why time step CFD simulations often fail so miserably...in each model run you are looking at individual pixels of the real world picture. What you can do is compare the experimental data to bounded min-max model output. So I can run a powering simulation model and vary the speed, temperature, salinity, air pressure, load condition, etc., which are things I know vary in real life, and what I get is not a powering line, but a powering band....and then I still add ~15% for surface roughness, fouling, hogging/sagging, seaway, wind speed and direction, whale snot, etc... A wise old author of PNA once told our class that you should never cut the powering too close, because if you make 1.0 knots over the contract requirement on trials they buy you drinks but if you are 0.1 knots under due to wind and tide you are in court.How often are full-size structures actually instrumented to a high resolution to validate a computer model or tank model for point-point correspondence?
That's because they have the same issues as above, except this you have to consider the materials as well...i.e. what is the actual thickness, modulus, and density of that piece of steel right there, for every piece of steel in the bridge. And then there is the whole temperature issue... a 40 degree F seasonal temperature swing results in a 400 foot long ship changing length by 1.25 inches for a cyclic stress of up to ~7.8 ksi in the structure where constrained....and we haven't even mentioned welds or rivets. This is why no matter how good your structural model is there are required factors of safety for public structures and vessels.For example, an iconic structure like the Golden Gate Bridge or Calatrava's Alamillo in Seville may have arrays of 100's of accelerometers, displacement sensors, and even laser scanners. There might be sufficient data from those to back-check analytical models. Most bridges have nothing - maybe a strain gauge or two to track gross displacement over time, but even that is rare.
There are plenty of tanks that handle models the size of small boats and wind tunnels that will take complete full size rigs. We still come back to the fact that numerical models (as of now) cannot account for all possible 'real world' input conditions and the physical models or at sea testing experiments cannot control with sufficient fidelity many of those same conditions (TBL I'm looking at you!).I recall a study of a full-size foiling moth in a tow tank at NAHL 15+ years ago. Pretty rare to see a full size boat that can fit an existing, fully-instrumented tank! Recent developments in MEM's pressure transducers are probably making full-scale tests with large arrays in marine environments more cost-effective, but I doubt it's commonplace. Most recent reports on sails or marine structures using dense sensor arrays are in wind tunnels or tanks at 'model' scale.
Sorry if this sounds pedantic, but the term "disagreement" is, I believe, the issue we are having here. What is "agreement"?....0.001%?...5.000%? This is a real issue if you want to delve into absolute "truthful" numerical models of physical items. The properties of an individual pour of steel vary ~2% depending on the physical location in the pour. And I know rolled shapes here in the US come in almost exclusively slightly less than 2.5% overweight because that is the mill tolerance, you buy by the pound, and an undersize piece is rejectable. FWIW, the best I ever got was 2% difference model to real and that was limited by the 0.05% accuracy of the very expensive load cell.You have a full-scale test that you can compare to both a computer simulation and an underlying, close-formed equation for a specific set of conditions. If there is disagreement amongst the experiment, the computer simulation, or the anlaytical equation, you have to figure out where the error lies. It could be in any or all of them.
Yeah, this is another one of those pedantic things that come from working with SS800-AG-MAN-010/P-9290.....(FWIW, I'm betting that Calatrava bridge is documented and detailed down to every flange and fitting. Ok maybe not my life, but will definitely risk a coupla beers)
