Nav Light Switch Panel
Discussion in 'OnBoard Electronics & Controls' started by papabravo, Jun 17, 2013.
  1. papabravo
    papabravo Junior Member
    I plan to install a tricolor mast head this winter when the mast is down.
    I like the tricolor at sea for distance visibility over the wave tops. I like the deck level nav lights in close quarters situations--so will keep those on board. (never switch between the two when there is a mariner nearby that will be confused by the configuration change)
    I could not find a switch panel that accomodates my needs, so am designing one myself.
    Does the attached file look like a good start? Please excuse my drawing, I am not an electrical engineer, and I used Google Draw to do this.
    This switch panel would be a subpanel off the main panel. I think... There will also be a small terminal block behind, just to keep things tidy.
    Circuit thoughts? Hardware suggestions?
  2. papabravo
    Corrected Diagream - Switch Label
    Changed erroneous DPST to SPDT.
  3. papabravo
    Meh. Never mind. I finally found something commercial to fit the bill.
    http://www.borelmfg.com/nav_light.htm
    The four circuit panel.
    I'd rather go commercial than build my own. It's just when I started looking, all the commercial panels were monstrosities of complexity and insulting to the eye as well.
  1. munthersaif
  2. sdowney717
  3. Florent
  4. cthippo
  5. Gianf1041
  6. SV_Harbinger
  7. the brain
  8. vondoom
  9. rich99uk
  10. Manie B
