Name for plan view transom notch around an outboard
fpjeepy05
Senior Member
Joined
Jan 31, 2010
Messages
379
Reaction score
38
Location
Hubert, NC
I’m looking for the name of a plan view notch at the transom where the running surface continues aft on both sides of an outboard. Examples: Hewes Redfisher/Bonefisher, Solo Skiff, Tango Skiff, Mullet Skiff, Handy Billy. This layout can move LCG forward and make getting in and out of the water easier. Visually it’s a bit like a swallow-tail or fish-tail surfboard.
Is there a term anyone here uses for this feature? If there isn’t a common name, what do you call ?
To avoid confusion with other layouts:
  • Euro transom: integral bracket/platform the hullside sweeps down into.
  • Notched transom: a notch in body-plan view, not a top-down notch.
  • Motorwell / well: engine space closed aft at the motor mount; sometimes limits trim-up
Thanks for any terms, examples, or references.
Picture is worth 1000 words.
I think Phil Bolger's Robin Jean wins the largest boat with this feature award
If you had to vote for a new term. Which option would get your vote?
  • Plan-view stern notch
  • Sponsoned transom (alt: Twin-sponson transom)
  • Swallow-tail transom
  • Fish-tail transom
  • Horseshoe transom
  • Keyway transom
  • Yoke Transom
  • SVEN transom — (Stern Volume Expanding Notch)
  • SWIM transom — (Stern Winged Inset Mount)
  • CWIM transom — (Center-Weighted Inset Mount)
  • PHAT transom (feature) — Paired Hull Aft Tails (alt: Podded Hull Anchor Transom)
  • WASH feature — Winged Aft Sponson Hull
I would call it a "transom relief".
For example one may have; "a 5' transom relief motor-mount".
When i was growing up, bottom extending aft of the transom was called "squat boards".
They make those extensions out of aluminum as well to add to jon boats. I think they call them pods. (I think)
If you are that deep in toward the middle why not extend the hull across the back?
