1. The Marketplace Forums can be useful for members who know one another well from forum discussions and offline communications and wish to post boatbuilding tools, drafting tools, molds and tooling, and other professional equipment for sale or trade. However, caution and good judgement should always be used. Especially when considering any business with anyone not already well known to you and trusted, due diligence must be used to confirm details and identity and be sure the transaction is safe before any money or property changes hands. Always use good judgement and perform due dilligence and follow these guidelines.
My little piece of peace
Discussion in 'Marketplace' started by masalai, Feb 5, 2009.
Thread Status:
Not open for further replies.
  1. Boston
    Boston Previous Member
    I need a lot more timber before I can say I have actually started
    Im just kinda goofing around with bits and pieces
    I never did settle on an actual hull design
    we basically have opposite design parameters
    if the weather gets ugly in a cat your going to want to avoid pounding and sacrifice speed
    in a semi displacement hull like a down east design Im going to be able to run from ugly at full tilt
    ( hell its what I do on land sometimes )
    there may also be the occasion where Im trying to get in somewhere before nightfall
    a redundant system of hopper feeds and boilers seems safest and by having more hp than needed I keep a lot in reserve just in case
    also these engines have almost no maintenance issues
    ttl my power plant weighs in at about a 2400lb dry were a comparable diesel weighs in at about 3500 lbs dry
    more than half a ton more and far less torque
    its also a lot taller
    my weight distribution is lower in the vessel but has a slightly larger footprint and thats assuming one large diesel
    two smaller ones would exceed the footprint of my four plus boilers
    Im always open to suggestion but given the amount of time and consideration Ive got into it Ild think that redundant systems are better than not
    only thing spooks me about boilers is lighting a fire in the bottom of a $250,000 pile of lumber
    enough about me on your build page though
    when Im ready to post my progress on things like skylights and windows Ill post it in a new thread
    untill then
    Ill just read along and keep learning about hull design
    best o luck with your build
    B
  2. masalai
    masalai masalai
    My sistership has recorded around 20knots (with a large version of the standard rig) from the grapevine, In ideal conditions I may get near that and at about 4862KG will rely more on prudence and waiting for a suitable weather window. 800mm draft will let me hide securely up many mangrove sided creeks if the need arises (mangroves make fairly good anchorage points) to tie off to...
    The fire thing is one of the reasons I have only diesel for the genset and all else is electric (240VAC via inverter from the 48VDC batteries for the galley, 48VDC for propulsion and 12VDC for the ships services & nav)
    The DuFLEX system seems far more robust than I had thought possible in any form of composite build. Boat feels good and (for me) looks good.... I still like your style of boat just that this suits my current needs:D:D:D
  3. Boston
    your multi hull is always going to be faster than my mono with less energy
    I can see you now drink in hand sailing along with a few bikini clad beauties
    or better yet unclad
    but the maintenance of sails and rigging both standing and running is huge
    your paying for speed one way or another
    me with fire
    you with rigging
    Im all for you and your a dam great inspiration to get my *** in gear but Ill go with btu's in pellets at a third the cost of diesel at $225 a ton and $3 a gallon respectively ( and that disparity is only going up )
    eventually diesel boats will be paying $5000+ for a fill up of a 1000 gallon tank and Ill be off the dock at a tenth of that for the same btu's
    $225 is retail an if I buy a few tons at a time I get whole sale price or about 40% off
    the fire thing is a sticky point and always has been
    boiler explosions dont exactly impress me either but I wont have time to worry about it if anything really goes wrong
    at 800 mm your sitting at about 32 inches draft
    Im aiming for about 44 inches so have a similar ability to head upstream
    and with a double keel we can both ground at low tide without damage
    ( I hope )
    tell you what
    soon as I get built Ill try heading down under and we can have a we built it ourselves party
    we will quibble over design details then
    untill then Im going to cheer you on like a drunken college fan
    maybe Ill get lucky and find a drunken college cheer leader to show me how its done
  4. masalai
    masalai masalai
    With lots of money to help defray your build and cruise expenses:D:D:D
  5. Boston
    that an a lot of great micro brewed beer
  6. masalai
    masalai masalai
    Well today's imagery is of the bow - fore-beam and chainplate assembly awaiting multiple layers of quadraxial cloth tape and the stern all taking shape and looking good...
  7. Manie B
    Likes: 123, Points: 63, Legacy Rep: 1818
    Manie B Senior Member
    Mas as always looking good, and great posts.
    Do you have a picture of a cross section of that forward beam.
    i would love to know how they put that together, i do assume that it is hollow? is it wood?
  8. masalai
    masalai masalai
    Manie, it is aluminium, a fairly heavy section and the ends to be glassed were carefully cleaned to remove all potential "grease", then sanded missing no parts else epoxy may not adhere properly, then wound with wet (epoxied) tape to specifications, allowed to cure, tidied up and fitted into place ready for more taping, and then the chainplate angles and fairing set, to have that part taped in - see post 483, 485, 490 and 501 each has a frame or two relevant to the process... You should be able to see the embedded clevis pin hole (made with 16mm ID SS tube - 2 "grooves" will be cut to take the rigging screw section, the pin is about 105mm long made from 20mm or larger stainless steel rod turned to fit with a head on one end and split pin hole at the other...
  9. Boston
    being an old school woodwright Im not to familiar with this tape
    can you describe it to me or give me the company name so I can look it up
    thanks
    B
  10. masalai
    masalai masalai
    Just "glass" cloth woven into specific widths and with various woven patterns for different uses - joins in composite structures after being glued and filleted using epoxy and "micro-spheres" mix... explained in detail in 'the scrumble project' I think... the link is in the bob oram link of my signature area, and also check out there for the ATL site, as there must be something there too... else get back to me and I will find some better information....
  11. Boston
    Ill have to look up
    "micro-spheres" mix as well
    thanks
    B
  12. judy
    Likes: 4, Points: 0, Legacy Rep: 123
    judy Oram 44C Builder
  13. srimes
    Likes: 31, Points: 28, Legacy Rep: 214
    srimes Senior Member
    What engine is that? I'd like to read more about it. I like the simplicity of single action w/ auto parts, but that's not the complex part of the engine. What kind of valve train does that use?
  14. masalai
    masalai masalai
    srimes, it is steam and if you PM Boston I am sure he will give you the data you require...
    judy, Thanks for the help :D:D - I have been up to the shed taking photographs for Boston and to put on this thread...
    On the way back, the big boys are playing with their boats - Maritimo (Bill Barrycotter) Stephan - who owns a chain of hairdressing salons has his big "pink" boat there and quite a few others... I took some video and if it works out OK I will post that, but mainly lots of still shots with the little work camera (so as to be within the 2meg size limit)... Racing Sunday - the last of the season... then they all go back to Europe and middle east to continue with a new series under altered rules....
  15. masalai
    masalai masalai
    For Boston (1) - is the join on the outside of the transom with cloth tape securing and "peel-ply" facilitating a cure and ready with a light sand after removing the peel-ply to paint by extracting the 'fat' from the surface... (2) - A join internally with fillet work (rounding) tape and peel-ply... (3) - heavy with layers of tape to strengthen the 19mm bulkhead that will partially support the mast step on the deck... (4) - partial build of the forward chainplate... (5) - surplus waste of two different mixes for epoxy & microspheres...
    Thread Status:
