You think you cannot afford a boat to sail? Here is one mans solution to a mini cruiser. Due to his age and a wife who decided the land life was more comfortable, he was left with a big catamaran, which proved to be too much to maintain and handle alone. So, he started to think of what was available for an elderly singe-handed sailor.
The smallest possible boat he could think of was a canoe. So, he bought a used canoe and designed a trimaran. The initial floats were sewage pipes and a rudder was added. The two windsurfer rigs were put on the forward parts of the outriggers. The boat also got two small leeboards, one in each outrigger. This time the boat sailed OK, although when it got some wind, it tended to heel and to take water over the outriggers.
The next step was to make the tri into a "mini cruiser" selecting simple and low-cost solutions as far as possible. The canoe stem and bottom need an external reinforcement to take grounding and provide some extra strength. The cabin was built from the understanding that the human body does not need more space than what is in a coffin with sitting headroom. This insight keeps cost down and makes it possible to build a small cruiser.
The cross arms are two aluminium ladders fastened to the sides of the hull. The ladders were bolted to fasteners on each side of the hull and to the pontoons. On each side of the front outrigger was placed a mast foot. The two windsurfer rigs were placed in these foots without stays.
The floats were sewage pipes and were heavy and have little buoyancy. They were replaced by floats built in Gaboon plywood with wooden reinforcements for fastenings and leeboards. The leeboards were built from wooden stringers, glued together. They are angled 45 degrees inwards in order to give both a lift to the pontoon and a force to prevent leeway. They are also angled with a five degrees angle of attack, something that is possible when only one leeboard is in the water at one time. The rudder and the rudder head were built from wood and can kickup. The motor is a 2 hp Honda. Cost was kept down through buying some used equipment but still cost two thousand US dollars. Building time was about one and a half month of part time work.
As can be seen from the pictures, the boat sails and goes to windward. It is slower than a full-size multihull cruiser or a beach cat. The boat has so low weight that it has difficulties to change tack without help with the paddle. The mast may need to be moved and reinforced as the masts tend to bend too much and to spill wind.
Just one mans simple solution to a sailing as an older person so he can have some fun.
The final jpeg is another mans simple solution to sailing with a Tiki 21 cat hull. The rig is cheap and simple for downwind and broad reaching courses. There was no comment about upwind performance.
