This is about the cats capability, not so much about the structure as we have covered the construction before. The cat we are talking about is the Tiki 21. This specific cat crossed the Tasman sea (between NZ and Australia, about 1500 miles) in 2017. The crew was a father and his 6 year old daughter.
The reason for the trip is a not unusual problem. The girl's mother, New Zealand-based went to Social Services, where she was divorced from the 6 year olds father and had to resort to professional help to find her ex-husband and daughter. The first time it happened was on the eve of a divorce hearing to decide which parent would have the daughter stay with.
The father and daughter went on a sailing trip which was meant to be between 2 NZ ports. The NZ authorities searched for the cat and crew when it did not arrive in the NZ port the next day. When the cat finally turned up in NSW in Australia, the father said he was surprised people interested.
The yachtsman gave an interview to the local media in which he was genuinely puzzled by the «mass hysteria» surrounding their disappearance: “the daughter made a 56-day cruise before she turned one year old, so a 27-day voyage would not be long for her”.
When asked how a catamaran heading for New Zealand Cove ended up in Australia, He explained that he had been caught in a storm on the high seas. The rudder of the catamaran broke and the wind started to blow the boat towards Australia. He had a repair kit to fix the rudder, but the weather kept him from doing so. Asked why he had not reported to authorities in Australia he said he was busy with other things. The boat had ample supplies for 30 days at sea “just in case of a delay in his one day trip in NZ.”
Back to the TIKI 21 capability. The Tasman sea can be a nasty place to sail in and you need to be a good seaman to make the trip unless the weather gods are very kind. But Tiki 21’s have not only crossed the Atlantic but also circumnavigated. Cooking Fat owned by Rory McDougall went global years ago. A Tiki 21 only has minimal bunk room and storage space so you will not travel in luxury but the cat will get you there.
The Tiki 21 is 21 x 12 foot with a weight of 800 lbs and a displacement of 1800 lbs. The 20 foot 104 x 3 mm aluminium tube mast carries a 207 square foot rig. The draft is 1.15 foot.
The jpegs below give an idea of construction. Mainly 6 mm ply and a lot of epoxy and timber.
And to give an idea of the performance of his near standard Tiki 21. “On this day, Little Cat was tacking through from a best of 96 degrees to a worst of 116 degrees, and maintaining an average 3 - 4 knots progress directly to windward. Working in our favour was a breeze in the golden range of 10-15 knots true, and Little Cat had a freshly painted (smooth) bottom.” His Tiki 21 has peaked at over 15 knots on reaches and can average 7 to 8 knots under favourable conditions without pushing too hard. He found good sails help enormously.
