Mudboat
Discussion in 'Inboards' started by MarshGator, Oct 17, 2006.
  1. MarshGator
    MarshGator Junior Member
    I plan to build a mudboat after the first of the year. I am currently looking for information on building a Louisiana Mudboat. This is a small boat 14’ to 18’ with an inboard setup. Looking for any help/information, hull design, and engine/hardware setup.
  2. longliner45
    Likes: 73, Points: 0, Legacy Rep: 505
    longliner45 Senior Member
    can you tell me what are mudboats for ,,,,never seen one,,thanks longliner
  3. MarshGator
    Mudboats
    Mudboats are primarily used for gaining access to areas with little water (3” or less and mostly mud), and areas with thick aquatic vegetation. The marsh mud here in South East Louisiana is mostly a couple of feet of decomposed organic matter (sort of like wet coffee grounds). The first boats were made of wood with inboard engines. Most now are made of wood and fiberglassed or all aluminum. The engine depending on boat size can be from a 5 or 10 h.p. direct drive, air cooled up to a Chevy V8, keel cooled, with velvet drive or any combination between. Take a look at these links.
    http://www.louisianafolklife.org/FOLKLIFEimagebase/FLImagesListing.asp?Page=482
    http://www.aa5au.com/duck_stuckinthemud2003_2.html
    http://www.teampersuasion.com/mud-boats.htm
  4. MarshGator
  5. longliner45
    mud boat
    do you guys use these for red fish?,,,,,,,,,and gators?
  6. MarshGator
    Yes. they can be used for almost anything you need to do in the marsh. They were first used by trappers and people who worked and lived out in the marsh. They are mostly used for duck hunting these days. Most duck leases will not allow airboats. Some people will build/buy a small version (~12 foot) and put a pop-up blind and hunt out of it.
  7. Lowater
    Lowater New Member
    awsome site. man that would be the ticket.
  8. tom kane
    Likes: 49, Points: 58, Legacy Rep: 389
    tom kane Senior Member
    Great fun in the mud and shallows.If you fit a trimmable shaft drive as shown you can go more places as the drive follows the bottom if shallow or it can be lifted level with the keel.No where it can not go_Other pics in my photo album.
  9. tom kane
    Diagram for drive for improved mudboat application.
  10. MarshGator
    Tom,
    Can you e-mail me the diagram? I am having trouble seeing the entire thumbnail. Also, any additional details would be helpful.
    Thanks
  11. tom kane
    I can e-mail to you my original Patent Application diagram and text of three pages plus diagram and other information and pictures as required.I would find it easier if you e-mail me direct to contact at www.arthurkane2002@webnet.co.nz
  12. Ari
    Likes: 15, Points: 0, Legacy Rep: 94
    Ari Patience s/o Genius
    The flat bottom mud boat at my place used the long tail out board -like Thai long tail.This kind of propeller will enable you to power the boat even in the soft mud without water, wet hard mud -need long pole to push the boat forward.A long pole is necessary incase you need to push the boat. Paddle doesnt work in mud.I used to run my boat over submerge timber tree- 1 feet out above water,push the bow across the blockage, blow the throttle to push the boat through,lift the propeller out from the water and slide to the other side of the log.With inboard engine this is not possible.
  13. bilgeboy
    Likes: 7, Points: 0, Legacy Rep: 45
    bilgeboy Senior Member
    This thread is a refreshing treat. Love the links. Felt like I was there. I feel I got me some culture, and had a bit of learnin'.
    Ce n'est pas?
    Merci,
    Mike
  14. tom kane
    I have had computer troubles,now all sorted I hope I will try to get up-dated with what has been going on.
