mould sealer?
Discussion in 'Fiberglass and Composite Boat Building' started by nevilleh, Oct 10, 2010.
  1. nevilleh
    Likes: 2, Points: 0, Legacy Rep: 53
    nevilleh Junior Member
    All these question guys !
    Is it worth puting mould sealer on my plug?
    Ive only used it once and i didnt think it made much difference.
    I have had problems before with the duratec sticking to the mould surface - i think it saps up the wax, so i was thinking the sealer may be the way to go for this .
    Ive pretty much ruled PVA out - im sure I will be corrected though . I just cant see the point of getting a fantastic shine with the wax only to cloud it over with the PVA ?
    Unless I should be reworking the new mould afterwards ? :(
  2. patiras
    Likes: 2, Points: 3, Legacy Rep: 30
    patiras Junior Member
    I've had problems with just wax on duratec. I use TR 910 and 900 on duratec. No need to get it beyond about 1000 grit on the plug; the mould polishes up dead quick.
    Al.
  3. Herman
    Herman Senior Member
    A mould sealer is your insurance. Get a well proven system that you are comfortable with, and that can be used in your circumstances. Do a test piece to see if the release is what you expect from it.
    I see Zyvax products used, but also Ferro FS10, even just using their sealer, and putting Meguiar M87 on top.
    I also see no point in using PVA, but for very bad moulds. I even made a polyester mould from a boat that was sanded with 220 grit. No shine, however...
  4. nevilleh
    yes, i think that is key - a test piece. thanks.
  5. jim lee
    Likes: 20, Points: 18, Legacy Rep: 247
    jim lee Senior Member
    Tend to disagree. We've had good luck wiping a thin coat of PVA on our plugs before making molds from them. Side by side tests, PVA released and without, the plugs came out in chunks.
    -jim lee
  6. Herman
    My biggest problem with mold release is a too good release. If your plugs come out in chunks, something is definately wrong. I do have some suspicions, but that is for another thread.
  1. UtahSignature
  2. pironiero
  3. hardguy007
  4. sailswede
  5. JohnMarc
  6. FiveO
  7. Fishbonemarine
  8. fallguy
  9. Felix Gruter
  10. bedfordd
