Moth on Foils: 35.9 knots(41.29 mph)
Discussion in 'Sailboats' started by Doug Lord, Apr 11, 2006.
  1. Doug Lord
    Doug Lord Flight Ready
    Moth on Foils!
    Foiling Moth Scow. Note the single wand and dual daggerboards. I wonder if the guy is using a single foil between the two daggerboards or a shorter t-foil on each daggerboard with the wand moving an axle between them or?
  2. Doug Halsey
    Likes: 158, Points: 53, Legacy Rep: 160
    Doug Halsey Senior Member
  3. Doug Lord
    Moth on Foils! Australian Nationals
    Thanks, Doug. They use the wand to control two separate foils but with the facility to "turn one off"-pretty cool.
    Heres a shot of Glen Oldfields wing equipped "Whisper": (Oldfield didn't race most races)
  4. Doug Lord
  5. Doug Lord
    Moth on Foils!
    I was researching a question on foil drag so reread Bill Beaver's excellent paper (see below) on the Moth. I found something directly related to the discussion here earlier(see red above):
    Although not intuitive, from a sailing perspective flap up
    (shedding lift) is more important than flap down (adding
    lift) because of the dire nature of the crash that comes from
    the inability to shed lift adequately.
  6. Doug Lord
  7. Doug Lord
    Moth on Foils!
    The French FFV have made a rule that all Moth sailors must wear helmets.
  8. Doug Lord
    Moth on Foils!
    The French FFV have made a rule that all Moth sailors must wear helmets. I wonder if you have to wear a helmet when you ride a motorcycle in France?
  9. Doug Lord
  10. Doug Lord
  11. CT249
    Likes: 116, Points: 63, Legacy Rep: 215
    CT249 Senior Member
    Any word on why only 13 boats started?
  12. Doug Lord
  13. Tiny Turnip
    Likes: 196, Points: 43, Legacy Rep: 743
    Tiny Turnip Senior Member
  14. Doug Lord
    Moth on Foils!
    That's quite a find! How did you run into it?
  15. OzFred
    OzFred Senior Member
