whitepointer23
Previous Member
- Joined
- Jan 12, 2011
- Messages
- 2,114
- Reaction score
- 51
Tom what engine did you have in the cam a boat in the pictures.
Note: This feature may not be available in some browsers.
Hi Whitepointer, None of the many motors I used in my boats were permanently installed as some were borrowed and a variety from the first evaluation model 900cc ford E93A to some very high performance motors from racing friends. I could use V/8`s sixes or four cylinder. My preference and most used was a ford GT high lift cam with ram tube Remote Fuel System because of it`s safety factors and the ram tube made the the high performance idle much better for boating.
V/8` were far to heavy for a 16ft x6ft hull and increased weight draft and drag. Removing a motor taking about 20 minutes because it was just a matter of disconnecting the drive shaft and four soft engine mounts with crash shackles. I often took out the inboard motors and and the drive and fitted an outboard motor to go camping between experiments.
The Pivotal drive is exactly the same as a conventional inboard install except provision is made for the shaft to lift up. This drive could have been used if people understood mechanical engineering many years ago and perhaps some one did try and was ridiculed and told "it will not work".
A volvo penta b20 would be ideal for a 15 to 18 ft runabout with the pivotal drive . They are lightweight. Strong . Simple and easy to hot up. There are still plenty around cheap. In sweden rally teams used to get 250 reliable hp out of them. Cool racing truck outdoor.
