Monocat Hull
Discussion in 'Boat Design' started by trimix, Apr 29, 2005.
  1. Monocat Hull
    Monocat Hull Junior Member
    The design and Registered Trade Mark of the Monocat®️ are mine.
    U.S. Patent Number 5038696
    Ships Hull
    *International Patent as well.
    Tested at Stevens Institute, Davidson Labs,
  2. Mr Efficiency
    Likes: 452, Points: 83, Legacy Rep: 702
    Do you have any drawing you can show ? Not quite getting the gist of it from those pictures.
  3. Monocat Hull
    You should be able to view the complete drawings by going to the USPTO, Patent Number 5038696.
    My Naval Architect was Tom Fexas.
  4. Mr Efficiency
    I did go there, but somehow missed the drawings ?
    EDIT: tries a different browser, and voila !
    I did build a boat somewhat similar to that many years ago, it had a tendency to weave in beam seas, I made modifications, but never quite eliminated the annoying tendency. The ride was superb, as good as any planing boat of the size I have ever ridden in.
  5. Monocat Hull
    We didn’t have any issues with a beam sea.
    We also blew the numbers off the test tank.
    If you ever want to talk let me know?
  6. Squidly-Diddly
    Likes: 74, Points: 48, Legacy Rep: 304
    Squidly-Diddly Senior Member
    what is bigg
    what is biggest boat built with this hull, and what speeds and mpgs?
    any typical Table with various speed VS mpg VS rpms, etc?
  7. fallguy
    Likes: 292, Points: 83, Legacy Rep: 10
    fallguy Senior Member
    What are the advantageous/dis of this hull form versus a regular catamaran?
  8. Monocat Hull
    The Navy built a 120ft. but it is classified.
    From all the tests the ”Hull” works very well.
    The speeds tested a 120’ exceeded 100 knots.
    Recommended minimum length 50’+
  9. Monocat Hull
    There were a few advantages as the “Bow” is always “Cutting” and the “Rearward Hulls” ie; ”Cat Aft” are providing ”Stability” with the “Tunnel” providing “Lift”.
  10. Squidly-Diddly
    says "website not found" and other "Clifton Yachts" search is just some charter company
  11. fallguy
    check the date on the post SD
