Hello everyone,
I've just finished building my first 24-foot planing outboard hull in epoxy plywood. After several trials, I really like the design of the hull, as well as its seaworthiness. Everything exceeds my expectations, so I'd like to take the next step, build a mold and make a few more units.
It seems that the use of polyester resin is more suited to the sector to which large skiffs like mine belong. Can I simply wax my hull several times and gelcoat then plasticize in large quantities without risking damaging my current paintwork through exotherm or problems between epoxy and PE? (My hull is composed of: epoxy, plywood, epoxy, epoxy primer, PU primer and PU paint).
Will I be able to create a hull that rivals my stitch-and-glue, in terms of rigidity and weight, using only fiberglass and PE? I'm aware that my whole internal reinforcement plan has to be revised for this, and I'm thinking of using PVC foam, but I confess I haven't made much progress on this yet.
