Molded dagger board manufacturing technique
Discussion in 'Boatbuilding' started by arekisir, May 27, 2014.
  1. arekisir
    arekisir Junior Member
    Looking at ways to build a dagger board.
    Rather than hand shape a core / glass / fair I was considering the following:
    Make split mold for expanding epoxy to use as core.
    Layup reinforcements dry around this core molded expanded epoxy core.
    Insert into a final shape split mold and infuse resin in.
    Has this type of technique been used?
    Alex
  2. keith66
    Likes: 31, Points: 28, Legacy Rep: 168
    keith66 Senior Member
    Why bother? Look at how a Laser sailing dinghys dagger board is made. Its obviously made in a split mould but is basically a foamed or microballooned polyester core with steel reinforcing wires inset into it to give it the required strength, no glass on the outside at all.
  3. Steve W
    Likes: 88, Points: 48, Legacy Rep: 608
    Steve W Senior Member
    Ive built daggerboards and rudder blades in a simple sheet metal mold, a method i learned from the late Malcolm Tenant and used on many of his designs. Basically you have a sheetmetal shop fold a piece of steel or aluminum about 1/16" thick the length you want with a fold in the middle to form the leading edge and open at a 45 degree angle, none of the local shops can fold to the nose radius i want so i run an appropriate fillet, there are 2 more 90 degree folds at the trailing edge where you attatch wood strips to clamp to, so what you have is a female mold in which you layup your laminate then bend in and clamp the trailing edge. As i recall Malcolm laid up a lot of uni at the thickest point and then filled it with a syntactic foam made of epoxy filled with polystyrene beads and pushes it into a jig to set the maximum thickness. I prefer to close the mold around a shear web and leave it empty if the chord id not too long. You end up with a molded gelcoated part with no fairing. I will be doing a pair of rudder blades sometime this summer for a Gemini cat this way, about $60 for the mold.
    Steve.
  4. SukiSolo
    SukiSolo Senior Member
    Actually the Laser foils in the UK were made from a foaming polyurethane around a steel mesh. I t so happened I ran into the company who made them a few years back. They may have changed the process and or materials since but circa mid 90s' that was the case.
    As far as I can work out the moulds for making foils could be pretty much any material. For a 2 off, I'd be tempted to make a glass one, off a pattern, but if you have access to sheet rollers, steel and aluminium might be OK as you suggest. Even coated ply or MFC would work OK with just a local shaped part for the nose (leading edge parabola) joined on. If you have a lot of expanding going on with the foaming core do not underestimate the clamping required to maintain shape.
