modified vee rocker hull with jet - planing/porpoise
Discussion in 'Hydrodynamics and Aerodynamics' started by richard gray, Jul 29, 2013.
  1. richard gray
    richard gray Junior Member
    I intend to use a jetdrive to push a 20 ft aluminium hull. 6 degree floor rise , keel has 6 degree of rocker starts at 6 ft forward of transom. i think it will get up on plane ,but may porpoise? how will this shape affect the jet nozzle ,will it be to level at speed the jet points down 4 degrees from level ( factory spec) the bottom at inlet is as manufacturer suggests, but no info on the rocker in hull?
  2. PAR
    I'm not sure how you're measuring the rocker, but 6 degrees of buttock angle will cause the bow to be very high. Post some pictures of her profile.
  3. richard gray
    Par: the rise of keel is 4 degrees. the question is, if the hull is in plane the bow should drop to a condition where the bottom is in a 2 degree rise, i know the jet drive points down to aft at4 degrees, so it should force bow down as it goes into plane. at rest the front 2/3 would be a 3* rise and last 7ft to transom would rise 3* so it is a rocker bottom. i guess this will affect the planing effect, and may porpoise. the balance is just aft of midship at engine /trans. i only have lines plan and 1/4 scale model shown at (members list )site.
  4. PAR
    Is this the project I talked to you about this morning?
  5. richard gray
    Par i thinks so? check my photos on member list site Richard Gray
  6. JSL
    JSL Senior Member
    A drawing would really help.
    A bit of rocker on a fast planing hull is common but 6 degrees is a lot.
  7. richard gray
    rocker hull at jetdrive
    JSL ; i can reduce rocker to 4 degrees. and flatten and widen the last 6 ft. aft. i have not modelled the aft end yet but crude lines plane is on the members list site.
  8. JSL
    JSL Senior Member
    Whatever that 'thumbnail' is, it isn't much help. Once a 'Lines Plan' (showing Plan, Profile, and Body Plan) is posted, contributors might be able to make some useful comments.
