Johan Strydom
Junior Member
- Joined
- Jan 23, 2021
- Posts
- 16
- Reaction score
- Location
- Cape Town
Sorry Bluebell I missed your first post. This is an idea that if the real calculations, and not opinions work out, maybe somebody with the skills to implement it, might notice it. I am playing Jules Verne. Hi-Tech materials as in Carbon Fiber etc. I have no CAD skills. I have not found the need to draw it, yet. I imagine a giant sea kayak with a domed deck, everybody inside. There can be a half transparent tube down the center for extra headroom, lookout, providing light inside. Sections can be made to slide open. There can be a passage down the center of the boat where the headroom is the highest. Either side of the passage the floor can be raised for storage under. There can be two shafts running the length of the boat either side of the passage. Each side can have a double row of recumbent pedalers, facing each other in a staggered pattern. The rotation plane of the axle and chain wheel will be the same. The removable bunks can be above the pedalers. My numbers are suggestions. A bigger boat will have much more carrying capacity compared to hull surface area? I see a racing 8 can reach 12 knots, which is above hull speed. That is possible because of the length to beam ratio? So if the beam is increased to enable two rowers side by side that advantage will be lost? And the surface area resistance might increase more than the extra power? The trireme reached 9 knots. Hull speed for 80' boat is just under 12 knots. At 10 knots a voyage from Norway to Iceland will take 3 days. I see a racing 8 is 65' long. I did not realize that. So in 80' you can fit in 10 sliding seat rowers? Will a racing 8 fitted with a Mylar fairing over the rowers go faster upwind? What is the difference in power output between a sliding seat rower and a recumbent pedaler? The pedalers power output is continuous, unlike the rower. A smaller boat will have to be open I think. Bajansailor thank you for all the links. Bluebell did I miss any questions?
