migt have a big problem
Discussion in 'Stability' started by gunship, Feb 10, 2010.
  1. gunship
    Likes: 11, Points: 0, Legacy Rep: 137
    gunship Senior Member
    This boat im theorycrafting (in maxsurf) was imported to Hydromax, and when i calculated everything, it turns out that my Cog is a little higher than my CoB. does that mean a naturallyunstable boat? i think so, but considering i have almost half the boats weight in the keel, and only the rig being any distance above the waterline, i find it hard to believe the CoG...
  2. Crag Cay
    Likes: 49, Points: 28, Legacy Rep: 607
    Crag Cay Senior Member
    Most 'normal' sailing boats of average proportions, have the C of G around or above the DWL. Obviously the C of B is always below this.
    You need to look at how stability works (in particular the movement of the C of B with heeling) in order to understand how having the C of G above the C of B doesn't mean you will have an unstable boat.
  3. gunship
    i assume its also because as soon as the boat tils, CoB rapidly moves sideways while CoG is stationary (relativley) and thus you still get a rightening arm?
  4. Crag Cay
    That's right a positive righting arm has to develop with heal.
    When completely upright (0° of heel) there is zero righting moment.
  5. jehardiman
    Likes: 1,167, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Crag is correct, CoG (KG) is generally above the CoB (KB), what keeps the boat upright is the positive GM which is linked to your idea of the CoB moving. Here is a explination of GM that I did for another thread.
    2 people like this.
  6. gunship
    Now that's covering the subject! thankyou people! :D
    also, i realized my thread title is misleading, it should have "theoretical" whithin brackets. maybe a "solved" too.
