Midship Construction Drawing
Discussion in 'Multihulls' started by ruminame, Jan 20, 2010.
  1. ruminame
    Likes: 1, Points: 0, Legacy Rep: 28
    ruminame Junior Member
    I am Doing a Trimaran for my project & i need to know do i have do draw 3 different midship drawing or i should draw the midship only for the middle hull?????????????????????
    plz if any one know then help me.
  2. TeddyDiver
    TeddyDiver Gollywobbler
    You gotto draw what ever drawings your project and/or yard requires to make important details clear..
  3. Tad
    Likes: 212, Points: 73, Legacy Rep: 2281
    Tad Boat Designer
    I think we need a separate forum for student project questions.
    The midship construction drawing needs to show how the entire boat is built. Presumably she's symmetrical about the centerline so you need to show half the center hull (Vaka) in a tri, plus the cross beam (Aka), plus the Ama, (outer hull). How all these pieces connect together is very important to the structure....there's a long thread on cross beams here somewhere.
    Good luck.
