The Wing Guy
Junior Member
- Joined
- Mar 9, 2022
- Messages
- 61
- Reaction score
- 26
- Location
- Atlanta
I have a 31' cat powered by a rigid self-trimming wing. So far, that has been working well. However I had a catastrophic failure of a Victron MPPT that fed both the battery and my electric propulsion motor with 86.7 volts instead of the usual 57.8 for a nominal 48v system. Fortunately the motor, the batteries and the battery balancer are all overvoltage protected. (Amazingly, the Victron has no overvoltage protection at all.) The motor would not, of course, operate until I got the system sorted out.
The episode got me thinking about electrical failures. Maybe it's a gray day, flat calm and my battery bank is depleted... and I am drifting toward some million dollar yacht. Wouldn't it be nice to have a backup motor. So I bought a tiny Suzuki 2.5 HP outboard. I started to think that the thing would sit at the back of my cat, possibly (probably?) never to be used. So I thought "How else can I use this?"
I have an ultralight pirogue that I have not been using. I have some airfoils that are of an OK, although suboptimal, profile and size to use as hydrofoils. They have adequate structural strength. It could be fun to zip around on flat water, so I am building a low rider: a foiling boat that flies at just 6" above the water. If I can find the right prop, I should be able to get it going about 20 mph (that sounds better than 17 knots). We'll see. If need be, I can add to flight height, but initially I think flying low is safer than flying high, given the experimental nature of this little boat. I'll practice crashing down from flight. I'm expecting that to be not too violent, but we'll see. In any case, working out the kinks under motor power will be easier to do than to learn to sail it and work out all the kinks at the same time.
I have a variety water states and wind to chose from, and can probably find (maybe) enough wind (with only small waves) to make this thing fly under sail. We'll see.
Do you think that having powerboat races on little foiling boats limited to say 2.5 HP would be fun? Would you be more apt to learn to sail on foils if the boat were closer to the water, and more docile than a typical wing foiler? I think that there could be a class of foilers that are easier to race and learn than the Moths. I'm thinking that there could be a market for a small boat that is as easy to sail as a Sunfish, but faster. This is all just wild conjecture, and I would not be the person to make a business of it. But it would be interesting to hear your thoughts.
