mikealston2428
Senior Member
- Joined
- Jul 25, 2011
- Messages
- 207
- Reaction score
- Location
- aussie
Hi all,
I've 2 questions about a Mercruiser MC1 leg.
Firstly after removing the leg for maintenance I refitted it to find a gear lube leak in the upper drive shaft that filled the bellow with lube.
I replaced the oring next to the retainer nut and reinstalled the retainer nut.
Leaving the leg off the boat to check for leaks I found that the lube is leaking from the inside between the shaft and bearings and not the outside.
What is causing this is there a oil seal that fits up tight against the drive shaft in the bearing assembly ??
2nd question with the leg off the boat and in gear should I be able to turn the propeller by turning the drive shaft ??
I can't turn the drive shaft with leg in gear and am wondering if I've got something not lined up correctly or is this normal ?
I would think it would turn easily or with it on the boat it would turn it and smash all the gears ??
Thanks
Mike
Thanks
Mike
