Note: This feature may not be available in some browsers.
If by "efficient" you mean (hydraulic output power)/(mechanical input power), then this statement is wrong, since the pump efficiency is varying with rotating speed (and flow and head), also for the flexible impeller type pumps, since they are somewhat "semidynamic". Only strict displacement pumps (piston, gear aso) are nearly independent of speed up to a limiting value.It is efficient at all speeds.
How efficient is waterpump at 2500-3000 rpm ?
I'd say it is efficient enough for its intended purpose, based on its overall success. Is there a specific reason for the question?
So the biggest V-? outboards use bigger capacity pumps or outboard setup is more heat efficient ?I just checked through Mercruiser's parts website. It looks like only the small engines (3.0L) relied on the Alpha pump with closed cooling. The larger engines (V6 and small V8) had a pulley driven raw water pump if there was closed cooling. Big V8's were Bravo only (which has no pump in the outdrive).
So, I think the Alpha drive has its limits as to the amount of flow that it can support. Probably depends on the sizing of your engine(s).
