mercruiser 4.3 ignition
Discussion in 'Gas Engines' started by Rubenster619, Apr 28, 2019.
  1. Rubenster619
    Rubenster619 Junior Member
    I have a 4.3 alpha one mercruiser. My ignition amplifier went out. Can i swap my whole distributor to a regular automotive one and still run the same?
    Likes: 2,293, Points: 123, Legacy Rep: 2031
    No, because of safety issues. Automotive distributors are not spark protected. A new part will cost less and be simpler. What is the year and what is it doing?
  3. Rubenster619
    Ok i still have distrubutor with sencor can i only use a regular ignition module to control it
  4. gonzo
    What year and model is it?
  5. Rubenster619
    The boat is a 91 larson the engine is a gmc 4.3 mercruiser alpha one
  6. gonzo
    So that is the one with the small coil and two plugs into the side of the distributor.
  7. Rubenster619
    Yes can i install that one instead of the iv thunder bolt ignition amplifier
  8. gonzo
    Can you take a photo of your ignition system?
  9. Rubenster619
    This is the problem i just wanna double check if i can replace that with a regular one from a normal gmc engine instead of this and keep my originial coil and distributor that belong to tge boat and have no problems
  10. Rubenster619
    It cranks but wont start and i live this is the issue
  11. Rubenster619
    so do u think is it possible
  12. 7228sedan
    Likes: 16, Points: 18, Legacy Rep: 60
    7228sedan Senior Member
    Did you run through the Mercruiser ignition diagnostic checklist? How did you confirm that the module is bad?
