Merc 40 4 hp - need help starting it!
Discussion in 'Outboards' started by Jack Flak, Feb 5, 2012.
  1. Jack Flak
    Jack Flak New Member
    So - I'm new to all this boating stuff (as in just bought an old jon boat with a 'like new' fully rebuilt Mercury 4 hp motor).
    I took the boat out and put gas in the tank and added the proper amount of 2 cycle oil. I pumped the gas line a few times, turned the choke lever to 'choke', put it in 'neutral' and the handle to 'start'.
    I pulled the rig cord a dozen times and more - nothing happens. then did it again and again.
    The motor is old but actually looks great - and the guy showed me the 'guts' of it that he rebuilt - looks nice and newish - he said he tested it and fished with it.
    but I get nothing to happen. What am I doing wrong??
  2. tunnels
    tunnels Previous Member
    You put gas in the tank and then poured in the oil??
    MIX FUEL AND OIL BEFORE you pour it into the fuel tank !! has to be shaken about for it to mix or just lays in the bottom of the tank! and then goes into the carburator !!
    Its easy to flood a 2 straoke motor !! Take out the spark plugs and clean .Have you checked the spark ??
    Two pulls on full choke and then push it back in again !! open the throttle about 1/4 the way and try again :D
  3. gonzo
    Likes: 1,454, Points: 123, Legacy Rep: 2031
    If you have to mix in the tank, always put the oil in first. The fuel sloshing in will help mix it.
  4. michael pierzga
    michael pierzga Senior Member
    Those motors are pretty simple. Check for a spark at the plugs.
    Check that gas is inducting thru the carb. Normally after you pull a dozen times you will smell the gas.
    If you have spark and gas, those simple motors start.
  5. Frosty
    Frosty Previous Member
    Lets see you bought a renovated motor of a guy that did it himself . You did not hear it running and now you find it doe'snt run..
    Hmm lets see now what the hell could that be!!!
  6. pistnbroke
    Likes: 34, Points: 48, Legacy Rep: 404
    pistnbroke I try
    go to the mercury forum on www.iboats.com this is one of the biggest boat fourms in the world ..well it was till they threw me off after 1034 posts ....bloody yanks ..... when you get it going the next thing to check is do you have cooling water flow ....
  7. Frosty
    If I had a forum Piston I would chuck you off it.
  8. pistnbroke
    pistnbroke I try
    If I had a forum Frosty I would not let you on it ....
  9. michael pierzga
    BDN Moderator ! Moderator !!!! HELP !!!!!!!!!!!!!! Frostys going after Pistonbroke with a loaded Black and Decker...
    Its look'n bad, real bad...
  10. Boat Design Net Moderator
    Likes: 143, Points: 43, Legacy Rep: 1004
    I believe they are only clowning around Michael ;)
  11. kenJ
    Likes: 5, Points: 0, Legacy Rep: 56
    kenJ Senior Member
    You didn't say, so getting to the basics, make sure you attach the lanyard/clip into the deadman switch or you will not get any spark.
  12. PAR
    There's a dozen or so things that could be causing this, from something as simple as a closed fuel tank vent to gummed up reed valves.
    The logical thing to do is take it back to the guy you bought it from and have him show you how to start it. While you're there make friends, buy him a beer and get a few lessons on how to use it, care for it and fix the obvious things that might need it, in the next year or two, like the impeller.
