Mayo
Discussion in 'Materials' started by yipster, Jul 11, 2003.
  1. yipster
    Likes: 97, Points: 58, Legacy Rep: 1148
    yipster designer
    cant find "mayonaise" under the search button while i recall reading an old thread, maybe my spelling? "mayo" 8knt calls it i found is a glasbubble or talk mix into the resin to mayo thickness witch sands of great?
    questions:
    just plain use without glas? apply with knife? sands really great? can be finished with topcoat paint? weight considerations? or how to get the laminate real smooth?
    :mad: / :) :?:
    yipster
  2. yipster
    yipster designer
    did some tests, calc or foamdust mix works great too and wow, it DOES sand of great, what a difference! potlive is much longer, it drips more than real mayo :D
  3. yipster
    yipster designer
    that were tests... and sanding the wrong side of polyster still remains a dogs job (had to use a male mold) mixing calc in resin i read here only reduces total laminate price, stiffens the laminate and reduces shrink but makes it also more moist sensitive... glasbubbles make it -like foamdust i guess- easy(er) to sand?
  4. gonzo
    Likes: 1,714, Points: 123, Legacy Rep: 2031
    Glass bubbles or microballons are "easier":) to sand. The main reason is that there is less material to take out, the rest is air. However they need to be sealed. There is always the danger of water entering the laminate through capillary action.
  5. Guest
    Guest Guest
    microballoons vs. microspheres
    I can't remember the difference between microballoons and microspheres - can someone refresh my memory?
  6. Guest
    Guest Guest
    Microballoons are made from phenolic resin and microballoons are easier to sand than microspheres.
    Microspheres are made from quartz / glass
    Fumed silca will help prevent running and sagging while maintaining a higher density. Microballoons or microspheres both result in a lower density lighter mix, but still run and sag.
