'MAYDAY' Distress Hailing
Discussion in 'All Things Boats & Boating' started by brian eiland, Jan 3, 2012.
  1. DCockey
    DCockey Participant
    A quick look through several 2011 catalogs of US dealers showed several portable combo VHF/GPS units but no fixed mount units. My guess is combos will become the norm in the next several years in the US market given the low cost of receivers and antennas. Fixed mount installatins may need an external antenna depending on mounting location.
  2. Submarine Tom
    Submarine Tom Previous Member
    Yes, I am well familiar with how they work. It is Michael who seems most confused and now I know why.
    -Tom
  3. Landlubber
    Landlubber Senior Member
    "Next you'll be trying to tell me there is a special name for the pointy end and the blunt end of a boat!!"
    ...I don't think so Poida, what for instance if it was blunt ended.....there would be sooooo many names that the Oxford Companion to Ships and the Sea would need to be created just to deal with then all......
  4. yipster
    Likes: 98, Points: 58, Legacy Rep: 1148
    yipster designer
    do think it would be wise to read up what is involved using this sort of equipment
    but see the Solas-threaty and Bazel agreement has since 2008 determent licences redundant
    and replaced this by a registration duty where user also gets his MMSI-nummer
  5. WestVanHan
  6. Poida
    Likes: 51, Points: 48, Legacy Rep: 497
    Poida Senior Member
    I notice that the radio operator did not respond to the Mayday call. Only responded to the word sinking.
    As Brian pointed out Mayday is from a French word.
    Who the hell speaks French any more???
    Poida
  7. hoytedow
    You are right that it has various meanings here.
  8. hoytedow
    The French?
  9. yipster
    yipster designer
    And when in distress we all are fluent nato alfa bravo charly's :p
  10. Submarine Tom
    Delta, Echo, Foxtrot...
    It is the international language of transport communications.
    Damn lucky for me as it's the only language I've got!
    But lets not muddle the waters here. Mayday was merely taken from French, the rest of your distress call would be in the language of the area. Because your most likely rescuer is going to be a "vessel of opportunity" who is not only near-by, but likely speaks the local language or has someone on board who does.
    -Tom
  11. Poida
    Poida Senior Member
    Hoyt, your kidding, the French still speak French. Man, they are sooo far behind!
  12. hoytedow
  13. Frosty
    Frosty Previous Member
    may day is the first day of the 5th month is it not.
    Not a good word if you stutter.
    MMMM--MMMM -MMM Fcking mayday !!!!
  14. powerabout
    powerabout Senior Member
    measuring rms voltage on a nmea wire may not show you anything
    scope is the only way to check for sure or laptop with hyperterm
