Maxsurf Stability Help
Discussion in 'Stability' started by burley1, May 2, 2015.
  1. burley1
    burley1 Junior Member
    Hi there
    I am currently working on a powerboat to comply with ISO 12217-1. The project is for a university project and I am running the calculations in Maxsurf Stability.
    When I start analysis the software comes up with a warning (6.3.2 Rolling in beam waves and wind - Error with area integration limits).
    Can anyone help with explaining what this means and how can I resolve it?
    Tanks fellow designers!
    Jack
  2. TANSL
    They can be multiple causes, poorly constructed model, evil entered parameters ... It is not easy to analyze what happens without more data because, surely, there is not a program error but an user's mistake.
  3. burley1
    Thanks for the quick responce TANSL.
    True that it would not be a program error. The hullform is a supported monohull. Could the complex hullform confuse the program?
    Cheers
    Jack
  4. TANSL
    Could I analyze your model ?. You can send it to my email, if you want to protect your design.
  5. burley1
    If you could have a look at what I'm doing wrong that would be amazing. How can I send it? There is no way I can attach it.
    Thanks
    Jack
  6. TANSL
  7. burley1
    On reviewing my work this morning I have found that my vessel is not required to comply with section 6.3 as it is a category C vessel. The vessel is now complying to the standards!
    Thank you for all your help.
    Jack
