Max steel plate curve without forming ?
Discussion in 'Metal Boat Building' started by MikeJohns, Sep 13, 2006.
  1. Raggi_Thor
    Yes :)
    I often write m2 and mm2 or mm4 when I mean m^2, mm^2 and mm^4.
    It saves time....
  2. MikeJohns
    Likes: 207, Points: 63, Legacy Rep: 2054
    MikeJohns Senior Member
    Ragnar
    I was refering to your spreadsheet (N/m) (N/mm) toungue in cheek.:)
    Thanks for your input
    Mike
  3. george allard
    Likes: 2, Points: 0, Legacy Rep: 7
    george allard Junior Member
    <off-topic personal insult removed by forum moderator>
    You can bend a steel plate 720 dregrees and it will still work.
  4. MikeJohns
    George Allard
    Ragnar is certainly a knowledgable peer and I was engaging in some friendly banter. It is often hard to properly construe the true nature of written messages. Which is why the little faces are there.
    As an engineeer I design but I do not have much experience of building; yards have their own approach and often very helpful rules of thumb. The steel plate is to be sent off to a remote area and since 8mm is a bit on the thick side I needed to know whether to get it pre-rolled or whether they could pull it to shape easily without distortion.
    Murielle is using 5mm plate which is a little different. Raggi’s approach is back to basics which is refreshing , but I have been bitten before with what you should be able to do and what a boilermaker is happy doing.
    I browse the boatdesign website while working and often have little time to thoroughly read through the math. Having taught engineering in the dim past I always scan through the units to check a calculation, hence what may appear a rather brusque response which was supposed to be a humorous ‘see me after class’ approach.
    In future please keep your posts devoid of personal insult. Your input re 720 degrees is also unhelpful . We could do with better posts than this, I look forward to your next effort.
  5. Annode
    Annode Previous Member
    What would expect that number to be with equal shallow compound curves in both x and y?
