Skip Johnson
Senior Member
- Joined
- Feb 12, 2021
- Posts
- 398
- Reaction score
- 233
- Location
- Lake Tenkiller, Ok, usa
I've got a small dilemma, current proa build has two lightweight 21' masts from sectional step tapered flagpole (~20# each). I had lifted them into place and set them in their ground sleeves glassed into the boat a couple of times and it was doable. But add a little 5mm dyneema and trying it with the trailer not hooked up to a relatively stable car isn't possible for an old man.
Quick and dirty solution (is there any other?) was a 16' stub mast collared at the cockpit coaming and braced at the base in a fixture resting on the berth flat, about 32" bury. Stub mast was prebent by a tornado in 2018, had been used in a couple of previous proas. 2/1 tackle and everything works quite smoothly, no longer fear a little wind.
The dilemma is the connection from mast to stub mast. Currently there is a hose clamp capturing a loop of 1/8" dacron line that the hook on the tackle engages. There has to be a better way. I'd like something that is easy to engage and disengage. Current thinking is an eye attached to the mast and a weighted hook that would drop out when loosened, perhaps with a tailing string to make it easier to snag when disassembling.
