I found a cantilevered beam calculator:
I saw that one too. Some of the outputs are meaningless to me. What would make it simpler for me is to design for the wind load and apply a safety factor to account for fatigue. Is there a standard safety factor or something designers use to account for this?
You would save weight by tapering the diameter or decreasing the wall thickness towards the top.
For masts of this height/size/load it seems overly complicated to use a tapered masts. Each complete rig should come in under 120lbs including battens, mast, sailcloth, hardware, etc. A 12' x 3" diameter x .25" wall 6061 tube weighs just 30lbs, saving even 10 lbs seems not worth the trouble. Also having extra material up top would be good for mounting stuff and probably help minimize mast bend.
You should also find out how much extra strength you need to resist local loads, such as compression from your booms, and the load from your halyard blocks.
The weight of the battens will be balanced relative to the mast and the halyard will be strung right next to the mast, and the halyard load will be small because this sail design will not rely on halyard tension to shape the sail. The halyard will be supporting 60lbs at the most. In other words, bending and compression loads from the halyard will be very small. Basically the only significant loads will be wind loads applied to the mast by the battens that encapsulate it and accelerations from the movement of the boat.
You didn't say whether the maximum wind load you found is static or dynamic.
The wind load stated was the maximum wind load I would ever expect, meaning if I chose to sail in 20mph wind with full sail and encountered a gust of double the wind speed. The rig design I have come up with is really all about easy, fast, reliable and safe reefing and trimming.
One source of dynamic loads is a gust hitting, and what resists immediate capsize is not only stability, but also the rotational moment of inertia.
This is an interesting benefit of the biplane rig, the weight of the rigs is outboard on the hulls, adding even more moment of inertia than a centrally located mast.
You have to estimate how many load cycles at what load you'll get per hour of sailing, how many hours you expect to sail per year, and how many years you want the masts to last, then make them stronger than your maximum dynamic load by the required factor.
Basically I will be using this boat for 6 months to sail to and around the Bahamas and back, then I will probably sell it. This is just a warmup for a larger more seaworthy boat, and to see if the sailing life is really for me. Regardless, I'd like the masts to last indefinitely, along with the rest of the boat. It goes against my ethical structure to build stuff that doesn't last, especially where people's safety is concerned.
I originally planned on using 3" x 1/4" wall 6061 aluminum, I am here to make sure that's an appropriate choice. Probably overkill.
