windfiderthai
New Member
- Joined
- Nov 25, 2016
- Posts
- Reaction score
- Location
- thailand
I have built several 50 foot aluminium catamarans using a multichine flat panel design.
These boat where quite successful but the build process was difficult and expensive.
I am considering changing the materials from alloy to cold molded mulichine ply to make it easier to build here in Thailand.
My question to the forum is regarding the beams.
The calcs for the bulkheads/stringers and hull skins are easy to work out but I cannot find any real reference books or info regarding the possible structure of the aft and main mast beams.
I have an old copy of Roger Simpsons book which is full of great info ,,but not specific enough re the calculation's for the beams.
The concept would be similar to Simpsons "truss beam" and "box beam" arrangements.
In the alloy plans I used 6mm with vertical stiffening section every 200mm welded at 100mm centers ,,but how to make this in ply!!!!
The calcs i have worked out so far are 12mm hull skins over 18mm ply bulkheads spaced at approx 1 mtr spacings with 40mm x 19mm dressed timber stringers at approximately 300mm centers all exoxied together with all items fully epoy sealed.
This seems to be the basic scantlings as referenced from the Gougeon Brothers excellent book.
Anyway I am rambling on now ,,
would be great-full for any comments or assistance .
