Mast Base/Post Timber
Discussion in 'Fiberglass and Composite Boat Building' started by Craig_Hastie, May 7, 2009.
  1. Craig_Hastie
    Craig_Hastie Junior Member
    Our plans call for a mast post/base made from oregon/douglas fir, just wanted to know if anyone has opinions regarding the suitability of this timber for this application.
    From what I have found online oregon has a average density of around 420 - 550 kg/m3, the lower figure being New Zealand plantation, which is close to where we are so may be indicative of local supplies, then again maybe not.
    I guess the crux of the matter is, is a harder timber more suitable?
    Any suggestions?
    Many Thanks.
      File size:
      34.2 KB
  2. Eric Sponberg
    Likes: 209, Points: 73, Legacy Rep: 2917
    Eric Sponberg Senior Member
    Douglas fir is a softwood that has very good strength and stiffness properties. I will specify it for masts if spruce is not available. Spruce is the best for its strength and stiffness along with light weight, and Douglas Fir is a little heavier.
    With construction like you show in your plans, that post is pretty big. You won't have any trouble with it in Douglas fir. Stick to the plans.
    I hope that helps.
    Eric
  3. peter radclyffe
    Likes: 64, Points: 58, Legacy Rep: 680
    peter radclyffe Senior Member
    just what you need, sruce is for topmasts, df for lowers
