Masonite (hardboard) as base for Fiberglass
Discussion in 'Boat Design' started by 500Lonepine, Jan 20, 2015.
  1. 500Lonepine
    500Lonepine Junior Member
    Hello,
    I am designing benches for a sailboat and am thinking about using masonite as a base form for fiberglass. in other words the benches would be made from Masonite then covered with fiber glass.
    Is masonite a suitable base structure for Fiberglass in a marine environment?
    Thanks!
  2. PAR
    Masonite will not hold up in the marine environment, but you can use it as a form, knowing full well it'll break down with moisture exposure. If the laminate is heavy enough, the masonite is simply a mold over which the wet fabric is applied, when it's dry, the masonite is just along for the ride.
  3. waikikin
    waikikin Senior Member
    Quite some time ago we used to use masonite as a contact tooling surface for fiberglass molding, the dense smooth side was coated with shellac, waxed then pva Then molded off, now melamine faced sheet or polyesterboard-coated ply is easier.
    Seen quite a bit in lockers & also perforated masonite used as a lining panel form 50-60-s boats typically cruisers..
    Given the choice I wouldn't use as a form to leave in.
    Jeff
