ondarvr
Senior Member
- Joined
- Dec 27, 2005
- Messages
- 3,201
- Reaction score
- 796
- Location
- Spokane. USA
As mentioned, 1% pigment is very low and may cause problems. And trying to build up 450 microns with a 1.7mm can also cause problems, especially if you're trying to use a brushing gel coat to do it.
Wax doesn't typically leave any surface discoloration if it's applied correctly, as in being buffed to a gloss. Even 100 coats won't cause a problem like that. Not buffing it off correctly can, and then you get a uneven rough surface on the mold that can be sanded off. This time you also mention the mold surface showing an odd surface too, so this is on the mold surface and being transferred to the part?
1mm of tooling gel is rather thick, and thick gel coat can trap air, plus VE tends to foam up a little. If it's applied thick, any air created by it foaming can't escape easily, so you can get a poor surface form the porosity that is transferred to the part, but is only the surface.
You have several things that could create a problem like this.
Is there a rough or odd surface on the mold in these spots, and are they in the same place every time?
Trying to get any gel coat, let alone brushing gel coat, to a thickness of 450 microns is not easy with a 1.7 mm tip. Why are you using such a small tip?
1% pigment is ultra low unless it's some super high concentrated pigment. Why are you using that low level?
Are you following the directions on the can for that exact mold release wax?
What catalyst and a what percentage are you using in both the gel coat for the mold and the part?
