Market for DB-1
Discussion in 'Option One' started by Portager, Jun 14, 2002.
  1. tom28571
    tom28571 Senior Member
    Will,
    I should say that I knew that the Wally is not really a tri hull but at the point where the chine meets the water, it appears to have a similar cross section to a tri. This is my problem with this design as applied to our boat. There is no way to get livable volume in a small boat with this design. The main hull is just too narrow, and like small multihulls it would require a very high superstructure.
  2. Willallison
    Willallison Senior Member
    Ah! Now I see where you're coming from Tom. A section of the hull in say the aft 1/3 would indeed resemble the centre hull of a tri.
    I've obviously not explained my suggestion properly. I'm not proposing that we adopt the Wally hull shape per-say. More that we could adopt a hull with higher angles of deadrise up f'wd to improve its rough water capabilities. True, a very fine entry, like the Wally's, would compromise interior space too much, but I think a balance could be struck to give us a little of both.
    Here ia few images of the sort of thing I mean. All developable surfaces, with a fine entry, flattening to lower deadrise aft. It probably still carries too much V aft at the moment, but it should demonstrate my suggestion better than I have so far described with words....
      File size:
      71 KB
  3. Nomad
    Likes: 2, Points: 28, Legacy Rep: 12
    Nomad Senior Member
    I vote for the S.S. Bathtub method! :D
  4. Nomad
    Nomad Senior Member
    For real now I (not a cruiser boat guy) think an Albinish style would look good and sell good.
    Just my .02
  5. Nomad
    Nomad Senior Member
    Any other Ideas. Nothing is progressing here much lately in this thread and we need it.
