Mariner 9.9- 4 stroke has no speed
Discussion in 'Outboards' started by Scott Mckenzie, Apr 4, 2019.
  1. Scott Mckenzie
    Scott Mckenzie New Member
    I have a 1992 Mariner 9.9 4 stroke outboard. It starts right up and idles great. And when i give it gas it runs great. The problem is I can't get any speed out of it. It is currently mounted on a 14' Starcraft V-bottom boat. At full throttle best I can get is around 7 to 8 mph I would think it should do at least twice that speed. And since it seems to run ok I don't know where to start looking for a solution. I'm taking it on a fishing trip out of state and would like to try and solve the problem. Any suggestions?
  2. ondarvr
    Likes: 372, Points: 83, Legacy Rep: 506
    ondarvr Senior Member
    There weren’t any 4 strokes in 92.
  3. fallguy
    fallguy Senior Member
    Leave the engine off.
    Put it in gear.
    Spin the prop.
    It should not turn.
  4. Scott Mckenzie
    serial number is OH 11654 and below that it says 1992 I just thought that was the year
  5. RAraujo
    Likes: 22, Points: 18, Legacy Rep: 114
    RAraujo Senior Member - Naval Architect
    There were 4 strokes in 1992 - I just don't know if Mariner had any...
    I remember some Honda 9.9 4 strokes by late 70's early 80's...
  6. ondarvr
    Yes, but we are talking Mariner, not Honda.
  7. fishwics
    fishwics Quiet member
  8. fallguy
    Had a barebones Lund 14 with an added casting deck.
    A 15 hp motor would barely get it over the hump. It was a rental motor, so I got a brand new 30 and it worked great.
    The motor is either tired or the prop is wrong or slipping, but you are asking a lot of a 10 horse.
  9. Mr Efficiency
    I was thinking much the same, and the load on board the boat might be relevant.
  10. Scott Mckenzie
    ok I made a mistake in year it says 1997 on serial umber tag. I put it in gear without running and prop will turn clockwise and it kind of clicks and in counter clock wise it does not turn freely it actually turn motor. Is this normal?
  11. Blueknarr
    Likes: 232, Points: 63
    Blueknarr Senior Member
    Sounds like you broke the shear pin.
    Small outboards have a safety feature that prevents engine damage if the propeller is suddenly stopped. Take the prop off and replace the shear pin. Buy a handful they are usually cheap and often fail. On my Honda it is a simple corner pin
  12. baeckmo
    Likes: 222, Points: 63, Legacy Rep: 1165
    baeckmo Hydrodynamics
    Nope, that clicking is quite normal; when in fwd gear, the shaft is connected to the pinion via one-way ratchet "cogs".
    Edit. Look at the part no 50 in the picDavid provided in #18; that is the coupling element with its wedge-shaped "cogs".
  13. DCockey
    DCockey Senior Member
    What is the weight of the boat? What is the weight of the passengers and gear when top speed was 7 to 8 mph? Where were the passenger(s) sitting?
    Do you have experience with higher speed from a engine of similar power in this boat, or are you assuming the top speed should be higher?
  14. DCockey
    Also do you know anything about the propeller on the engine? What was the engine previously used for? What is the "shaft length"?
  15. fallguy
    Your prop is okay.
    Sorry; wish it was an easier answer.
