WarthogARJ
Junior Member
- Joined
- May 8, 2021
- Messages
- Reaction score
- Location
- Sheffield
Thanks, good points.
And I misread his question in any case, I missed the point he's asking about the actual drawings in trhe Gallery section, and not specifically about DESIGN a boat per se.
It obviously depends on your objectives, but I see the hydrodynamics as one of the most interesting aspects of being an amateur/solo designer (as in not trying to do it for a living, and not working in a company).
You don't HAVE to be a CFD specialist to do reasonable work.
Although by "reasonable", I mean you would need a pretty strong technical background, and to understand the hydrodynamics involved.
Sure, if you don't have that, and aren't that interested in attaining it, you could have someone else to do it for you.
And copying an existing hull design (assuming they did it right themselves!).
Or else if you're not too concerned with an optimal hydrodynamics design, you can revert to one of the empirical procedures that were used before CFD became so available.
But to do CFD you don't need a high end CAD package, and any high end package will in any case be able to create and export something you can use as a mesh in a stand-alone CFD package.
Like with openFoam, which is open-source, you can create your own mesh in it.
And export it to CAD packages when needed.
OpenFOAM v6 User Guide: 5.5 Mesh conversion https://cfd.direct/openfoam/user-guide/v6-mesh-conversion/
I'd be very surprised if that's not possible in any CAD/design package you've want to use in actually designing a boat.
Here's a good description of CFD packages:
"CFD software packages fall into one of the following four categories, more-or-less: CAD Embedded, Open-Source, Semi-Comprehensive (often for with niche specializations), and Comprehensive."
A Comparison of CFD Software Packages — Resolved Analytics https://www.resolvedanalytics.com/theflux/comparing-cfd-software
AutoDesk CFD is what you'd use if you wanted an integrated package with CAD in the AutoDesk system where fusion 360 lives (and is no longer free, just trial for a year for non-commerical use).
But it's NOT opensource...:-}
Ansys has Fluent, and SolidWorks has "Flow Simulation".
In any case, once you got an initial hull design, you could then go onto see if it met your other objectives.
If not, go back and adjust things and run through the CFD again.
