The differences between Duratec products and something like Evercoat may be significant, or irrelevant depending on the desired results for the specific application.
The first difference is viscosity, Evercoat and similar automotive primers tend to have a lower viscosity due to how they are used and the typical auto body shop equipment. Most of the time a high build isn't required on cars, yes they have high build primers, but high build in the automotive world is different than in the composites world. High build in automotive is 5-10 mils, Duratec standard primers easly build to 30+ mils thick, the Duratec High Build primers can be built up to 125+ mils if needed. If someone desires a lower viscosity with a Duratec primer they can add a reducer to get it where they want it. Adding the reducer will allow it spray, level and flow better, but can reduce the amount of build you can achieve at one time.
The base resins are different too, Duratec is targeted more to the marine, aerospace and mold building markets, these market segments tend to require higher heat distortion temperatures and better physical properties.
The other market where Duratec products are used is in high end automotive restoration and modifications. The Corvette restoration world uses them a great deal, others do too.
Most people don't realize how many different primers there are in the Duratec line up. You can have an easy sand primer, or ones that are formulated for more demanding situations.
There are two lines, the polyester based products and the VE based products, each having many different nuanced options and colors. Polyesters have a heat distortion temperature around 200F, the VE versions close to 300F. The VEs are frequently used in the high end car restoration market due the high HDT, they can paint the car with a very dark color and the surface doesn't distort from the heat in the direct sun. The VEs are also used below the waterline, they make for a very good primer and/or barrier coat base for long term immersion.
