manufactuer or id help
Discussion in 'Powerboats' started by Pointman, Jan 28, 2012.
  1. Pointman
    Pointman New Member
    permission to come aboard. please help id this 14 ft fiberglass boat and or manufactuer if this is the proper area. no markings or numbers found anywhere
  2. philSweet
    Likes: 609, Points: 113, Legacy Rep: 1082
    philSweet Senior Member
    It's got a reg no. Run it through the DMV.
  3. Pointman
    Pointman New Member
    Registered as kingfisher but can't find this design anywhere in kingfisher archives.
  4. philSweet
  5. Ike
    Likes: 511, Points: 113, Legacy Rep: 1669
    Ike Senior Member
    Look on the outside of the transom for the Hull Identification Number. it should be in the upper right hand corner. The number should look like this XYZ12345A999
    the XYZ part is the manufacturer ID code (MIC). The last two digits are the model year.
    Go to http://www.uscgboating.org/recalls/mic1.aspx and look up the manufacturer using the MIC
  6. Pointman
    Pointman New Member
    No numbers or nothing
  7. Ike
    Ike Senior Member
    Then tracing the registration numbers is your only recourse
