Manie's Microcruiser
Discussion in 'Boatbuilding' started by Manie B, Jun 14, 2009.
  1. Angélique
    I don't think that's expensive for all the building materials you used to build a 5.05 m (16½ ft) seaworthy sailboat incl the rig, and all the extras you summed up there...
    122 k ZAR in EUR = € 8,388.71 - - - 122 k ZAR in USD = US $ 11,628.43 - - - (at present)​
    ‘‘ a hell lot of money with ZERO ZIP ZILTCH RESALE VALUE ’’ - - 5 years sitting in a bar would have been more expensive, and now you have the boat . . ;)
    However the cheaper and quicker alternative is converting an old worn out GRP boat into a seaworthy craft suitable for all seasons in all oceans like Roger Taylor does . . :idea:
    P.S. - (info about Roger's new boat is linked in post #923 & #924)
  2. Manie B
    Likes: 123, Points: 63, Legacy Rep: 1818
    Manie B Senior Member
    :) Angelique - you are absolutely correct (sitting in a bar) :eek:
    Anyway, my advice to people is always to first look what available used to fix up. Here is South Africa we have so little choice that you might as well build, and having said that trailer-sailers are non - existent.
    I'm a huge fan of Roger Taylor and cant wait to see his next adventure!
  3. Manie B
    Well my mast "aid" is ok
    still a lot of work to do but the basics is there
    Now I have also designed an adjustable 3 point pulley and rope system to hold it vertical so that I can lift the mast in and out of it's socket manually
    Those pics should be out next weekend ??
    It is very easy to pick the mast up AND it is very easy to lift it up and down once it is in the vertical position - you just need some form of "assistance" to stabilise it. That's next !!
      File size:
      214.6 KB
      File size:
      220.8 KB
      File size:
      208.5 KB
      File size:
      228.8 KB
      File size:
      209 KB
      File size:
      201.2 KB
      File size:
      209.6 KB
      File size:
      210.5 KB
      File size:
      274.5 KB
    Angélique likes this.
  4. Angélique
    Tell your wife boat building is actually a money saving project . . ;)
    Smart mast rise and lowering system [​IMG]
    Can the backside of the tabernacle not be closed with a plank to the height just below the tilted mast, this for more lateral rigidity + stability of the tabernacle during lowering and rising of the mast when the boat is in the water and might be wobbling.
  5. Manie B
    good point - and yes it could
    for more lateral stability I'm working on my next "invention" :eek:
    = a yoke that slides freely up and down the mast
    it is pulled up by a rope from the bow to the top of the mast and then down to the yoke
    and the yoke is attached on it's sides to fixed ropes attached to the hull
    so when you pull the yoke up you also tighten the "side stays"
    this means the mast is upright when you lift it out of it's socket
    thus one rope to pull to keep every thing upright
    all sounds very weird
    but will post pics soon
    to get the mast up is EASY
    I'm worried about getting it down ?? :confused:
    "Tell your wife boat building is actually a money saving project" :)
    I had to promise wife and children that I will finally repaint the inside of the house before I start the next boat
    So the next boat is going to be flippen expensive ;)
  6. Manie B
    sorry here is the pic of the yoke
      File size:
      188.8 KB
  7. Manie B
    Well folks so far so good.
    Everything works well so far and there are a couple of things that I will change at a later stage BUT I need to get to the water first to try the rig out in a real world environment. The plan is just to cruise around at first in light winds to test the concept and to get the "feel" for what is good and what is not.
    There are more questions than answers at the moment but a shake down cruise will answer most of that.
    It all works. It all seems ok. The mast went up AND down easily.
    The joke system works easily and I will take many more pics next weekend when I raise it again for another test run.
    Launch day is the long weekend coming up 14 to 16 June !!
      File size:
      139 KB
      File size:
      162.5 KB
      File size:
      176.8 KB
      File size:
      144.3 KB
      File size:
      105.4 KB
      File size:
      91.5 KB
      File size:
      93.1 KB
      File size:
      84.1 KB
  8. Manie B
    Hard to believe that it's been 5 years.
    Jeez where does the time go to :mad:
    First cuts 13 June 2009
      File size:
      160.2 KB
      File size:
      170.8 KB
      File size:
      188.4 KB
      File size:
      169.3 KB
  9. Manie B
    When I look at the pics of the trips over the past 2 years it seems crazy the nonsense that I have been getting up to :p
    Anyway really looking forward to some sailing adventures :D
    I had some good times far away from the mad crowds !!!
      File size:
      211.4 KB
      File size:
      127.4 KB
      File size:
      126.3 KB
      File size:
      151.1 KB
      File size:
      193.6 KB
  10. MoeJoe
    Likes: 18, Points: 8, Legacy Rep: 85
    MoeJoe Junior Member
    Awesome stuff! Looking forward to your first sailing trip report.
    Appreciated if you could explain the sail control arrangement.
    Is that sailcloth the final one? Looks pretty thin when rolled up.
    Performance to windward will be interesting, and if there will be a noticeable difference on the "bad" vs the "good" tack.
  11. masalai
    masalai masalai
    Hi Manie, My boat "cno" was sold and is undergoing a major refit (the new owner is talking carbon mast - figures he can build cheaper than Au$17000 for an alloy stick - - and solid wing sails?) I am keen to borrow it for a week of test sailing next year.... We will see... CNO is based at Cairns...
  12. Manie B
    Hi Mas,
    Happy / Sad to hear the boat is sold, obviously a crazy time in your life.
    From the friends and family that we have in OZ we know the economy is down and money very tight.
    Anyway good luck with your life and next time build a small one man boat ;)
    Take care and look after yourself.
  13. Manie B
    MoeJoe the sail is controlled by an uphaul (halyard) attached to the Yard,
    a downhaul attached to the boom, (with these two you can pull the sail tight or loose as they oppose each other)
    a roller reefer on top of the boom to furl the sail
    and a standard mainsheet to let the boom out
    then there are 2 "lazyjacks" of sorts attached to the front and rear of the boom to hold the boom up when you lower the sail to roll it up
    the Yard and boom has parrels to hold it against the mast.
    I'm not sure if my terminology is correct but that is basically it.
    The mast lifting yoke and ropes I will show in photos next weekend because that will explain that easily.
    The sail cloth is 220 gm Dacron so hopefully it is strong enough but time will tell.
    Measuring the different speeds on different tacks is going to be VERY interesting.
  14. Manie B
    Good News
    Well folks "Fargo" is finished !!!
    It is a joyous moment because now I can spend the next week getting her ready for the "sailing" launch next Saturday 14 June.
    A lesson to be learned for all prospective boat builders out there :-
    The little jobs that we all see as "quick" jobs, are never small or quick.
    I simply cannot believe how much time I have spent over the past FOUR MONTHS doing these so called "small" jobs. You wake up in the morning and it looks like you haven't done a thing the previous day, it is soooo frustrating. My answer was basically just too shut the mind off and just carry on regardless, some days are fun but other days are just plain boring and frustrating. Bottom line is you just have to get the head down and the "backside" up ;)
    But the feeling of accomplishment that you feel when you wake up on a day like this, is priceless. It puts a spring in your step and a feeling of well being that makes you feel 20 again :eek:
    So for all the Saffas :) the plan is now to leave Fargo at Bayshore Marina (Vaaldam) permanently. If you see me on the water please stop by and come and say hello. If you want to come and sail with me you are more than welcome. We will obviously do the "Around the Island" race next year February but you will see me often enough with some of the other regattas.
    I will still do my long distance trips to Villiers and Frankfort because that is really what I live for and enjoy. My plan is to go down to the boat regularly because now I have my own "cottage" on the water, and spend most weekends there. I will post new videos on Youtube and keep the Blog and Facebook updated regularly.
    I say "most" weekends BECAUSE........
    I have officially started my "TEN"
    basic drawings are done
    materials are on order
    and the first cuts should happen before end of this June :eek:
  15. colfar2
    Likes: 8, Points: 8, Legacy Rep: 92
    colfar2 Junior Member
    manies microcruiser
    Manie
    Have followed your build with interest over the last few years and is fantastic to see you are at the finish line. As you said there some tough times when building your own boat and gøød on you for pushing through. What made you decide to moore at bayshore as opposed to dick mantens on other side of dam ? Can't wait to see her on water with wind *?? sails
    Cheers
    1. Manie B
