Male fiberglass mold & finished surface
Discussion in 'Fiberglass and Composite Boat Building' started by erikhaha, Mar 25, 2009.
  1. erikhaha
    Likes: 4, Points: 0, Legacy Rep: 66
    erikhaha Junior Member
    Ok, I have made a male mold that I am going to fiberglass(see attached picture). My question is what is the best way, or tips/tricks that you guys have used to reduce fairing once the part is glassed? I hate sanding.
    I plan on glassing it with polyester resin, used for surfboards, because I have a lot of it and it is fairly cheap. I also have a lot of chopped-strand mat that will be used. Not sure the weight, but it is approximately 1/16" thick. After 2-3 layers of fiberglass I want to use gelcoat for the finish.
    I have never made a fiberglass part from a mold before, but I have researched it and I am pretty sure I am going about this the correct way, I just want to minimize the finishing sanding.
    Thanks
  2. Roger Moren
    Roger Moren New Member
    If your male mold is fair the surface should be fair. But you are going the have to fair and sand. I would recommend, mirco balloons, "spheres" not talc if you don't like sanding, they sand easier. It looks like a small hull so there would also be a weight saving. Get a mask.
    For what it is worth.
  1. Marguerite
  2. PennDude
  3. pironiero
  4. Scuff
  5. Scuff
  6. jangr
  7. bjdbowman
  8. Jetboy
  9. Cat Cruiser
  10. tugboat
