Old Primer - Blast or Revive?
Discussion in 'Boatbuilding' started by m-s1, Dec 11, 2005.
  1. m-s1
    m-s1 New Member
    I am contemplating the fitting out of a steel hull which was blasted and primed over ten years ago, condition is good but I know that the primer is way past time limit for overcoating. My question is in two parts, firstly is it possible to revive the primer without having to reblast and secondly, if blating is necessary does that have to be back to metal or would brush blasting be sufficient? Advice gratefully received.
    Matt
    Likes: 2,412, Points: 123, Legacy Rep: 2031
    If you are carful, it is possible to etch the old paint with a blaster. It is way faster than sanding.
