Lugger Diesels outlawed.......!
Discussion in 'Diesel Engines' started by apex1, Jan 8, 2009.
  1. FAST FRED
    FAST FRED Senior Member
    yes this is what i meant, but oh God those Komatzus they had cast iron pistons!!!
    Most cruising boats will have engines with a high power rating (From the Add dept) and then cruise at the lowest RPM and fuel burn they can do.
    The usual cruising speed is low the really high power output engines can suffer wet stacking and loads of other maladies.Including a short service life.
    The construction or farm equipment marinizations usually work best at these reduced power levels, hence the use of a Komatzu or on smaller boats the Ford tractor engines.
    Cast pistons , esp with square cut , rather than trapozidal rings , will do best at 30%- 60% power cruising that could kill a super turboed high power engine.
    FF
  2. apex1
    apex1 Guest
    :cool: thanks epo.. to back TAD´s recommendation wich I take seriously anyway. :cool:
    But I asked for a substitution of a 23 ltr. displ. engine w 550hp cont. @ 1500rpm:D
    I easily can get these horses out of less than half the metal still cont. rated!
    The Lugger I started with was designated to propel a 1.5 meter dia CPP, 2 Alternators a hydr. PTO, 2 ac compressors without notice, and still being able to push the 90´ metal trough uphill at sufficient speed.:p
    I know that I don´t need that power in 99% of the time cruising, half of it is more than sufficient. But....Butt.....:rolleyes:
    I like the peace in mind, that my precious butt is brought home safe.
    @ F F ..... I subscribe to that!
    Regards
    Richard
  3. apex1
    apex1 Guest
    Did I read between the lines that the CAT C18 might be one of the kid´s?:rolleyes:
    So is the MTU / DD S60 !? ...... or what can it mean that there are so many postings about the S60 here:
    http://www.dieselenginetrader.com/diesel_talk/
    BTW.. as mentioned above I got a quotation for the CAT C18 @ 83.000 USD Bobtail... do you have an idea if the Cummins KTA19 is in the same ballpark?
    Regards
    Richard
  4. apex1
    apex1 Guest
    It seems to me that I completely missed the recent IMO regulations ! ?
    Who is able and willing to point out the affects on YACHTS in comparison with FISHBOATs ?
    The reason for this silly question? I get my boat registered as a commercial fishboat with ease. So possibly circumnavigate some cliffs and stay with the original design.
    Thanks
    Richard
  5. Tad
    Likes: 239, Points: 73, Legacy Rep: 2281
    Tad Boat Designer
    In this country (NA) right now Cat is giving engines & equipment away to get them out the door. I have no experience with the newest Cat's, I do know some Lobster fishermen in Maine have replaced them after few hours. The same guys loved the Lugger's.
    The 60 series MTU is far smaller than the others we are talking of. Again I'd get serious about the Cummins KTA19 and the Mitsubishi S6R. Prices delivered in Turkey will vary with exchange rates, I would talk with the respective dealers asap.
    Little story....
    A local (BC Canada) towing company has recently built two new tugs for towing logs (saltwater). The first was delivered last winter (Feb08) and is 45' by 20', draws 10'6" (48grt) and is powered with twin Cummins KTA19 (500hp @1800) with TD 5222 gear turning 62" by 52" four blade wheels in nozzles. The second boat is slightly larger and was delivered around Christmas of 08. She is 53'6" by 24'4", draws 12' and carries 10,000 imp gallons of fuel. She is powered with the Mitsubishi S6R's, (500Hp @1350) with the same TD gears turning 68" by 67" three blade wheels in nozzles. Estimated bollard pull is 41,000 pounds vs the earlier boat's 39,000 pounds. Consensus is that the Mitsubishi's produce slightly more power and cost less to purchase at this time. Otherwise the two are pretty equal, only time will tell....
  6. apex1
    apex1 Guest
    Thank you TAD
    we pay almost the same prices here than in the US exc. Transport. There is no Import tax on such equipment and pricing here is in € or $ anyway.
    What about are the KTA 19 and the S6R in USD there? Playing with the local dealers means my grandchildren enjoy the boat! I still have only children.
    Regards
    Richard
  7. peter radclyffe
    Likes: 97, Points: 58, Legacy Rep: 680
    peter radclyffe Senior Member
    KEIVIN
  8. peter radclyffe
    KELVIN
  9. apex1
    apex1 Guest
    Thanks Peter,
    the Kelvin are well known in the commercial fleet, but too beefy for me. I´ll go for the KTM 19, and that is called overkill already by my yard.
    Regards
    Richard
  10. peter radclyffe
  11. Tad
    Tad Boat Designer
  12. peter radclyffe
    thanks Tad, i was unaware of all this, in europe cats have replaced a lot of gardners, kelvins, etc because their earth moving suppliers are so numerous,
  13. apex1
    apex1 Guest
    Peter
    the CAT reputation in the European marine community had nothing to do with other activities of the company. The engines were cheap, reliable and easy to service worldwide. The 3608 for example was a good engine too (all 36xx).
    Regards
    Richard
  14. powerabout
    powerabout Senior Member
    36** thats a monster
  15. apex1
    apex1 Guest
    Not really, did you notice what I was looking for?
    and btw. I have found the engine and can get it certified!
    Regards
    Richard
