But it got me thinking if one was looking to transport some cargo by sail on a shoe string budget how would you go about it?
I'm in Fiji where the problem is not only cost, but having to cross ~100m of coral flat to get to the beach.
During Covid a mate and I built a 24m/80' cargo proa to service remote maritime communities, delivering small-medium quantities of goods back and forth at regular intervals. Took us 2 years of 40 hour weeks to build the boat and a 28' tender. About half the time was spent talking, testing and breaking stuff.
The long hull is box section 800mm x 800mm. The 12m short hull has 2 bunks, galley and nav space. The entire boat is built from knitted glass flat panels (no core) infused on a table andf painted with water based house paint. The low panel stiffness was solved with bulkheads at 800mm centres. The chines and gunwhales are male/female joins included in the infusion. Squirt glue in the female, push them together and wipe off the squeeze out. No jig or building frame required. Materials cost 6 years ago was ~$Aus30,000/$US20,000.
I brought it to Fiji for assembly and testing. Took a while as we had to build a shed and boat ramp. I spent the time talking to villagers and experimenting. The original plan was conventional sails on unstayed masts, the same as on Harryproas. The cost of the sails and gear required caused us to look at reefable wing sails, which I built and tested. Lower cost, lower loads and easily built, but complicated to use.
I had been playing with kites on boats for 20+ years, but found the launch and retrieval (especially when they fall in the tide) issues overcame the benefits (no heeling, more wind up high). Another mate came up with a solution which flew the kites on short lines, using a lightweight mast to deploy and retrieve the kite. He also switched to paragliders, which are larger and available second hand for much less than a kite. A huge benefit is that they are self trimming from hard on the wind to a broad reach. Two people can handle the boat on 1-2 day voyages.
The gliders meant the boat could be half as wide and the 150 kg masts replaced with 20 kg versions. The final result weighed <1.5 tonnes when launched (floated clear sitting on 7 empty 200l/40 gal drums), has since had 2 kw of solar panels, 6 kw electric motor, 8 kw hr battery, anchors, etc added, now weighs about 2 tons/tonnes, draws about 50mm/2".
Freight is carried in boxes on the long hull deck. Sail across the reef just before high tide, unload the village's box(es), load their exports and sail back across the reef. Or put a couple of tyres under the boat and sit on the coral flat (dead coral in the process of being ground into sand).
1,000 hours of labour here is about $US3,000. Overheads are low. Materials have gone up a bit, shipping costs have gone up a lot. Depending on the survey requirements, and assuming a production line approach, a boat capable of carrying up to 2 tons of cargo offshore, or 10 tons in sheltered water could be built for less than $US40,000. This compares with the latest interisland ship, an almost derelict ex ferry which cost $US2 million and caught fire on an early trip. 50 cargo proas, which don't rot or rust, can be built locally by semi skilled labour and cleaned by a couple of kids in knee deep water. They would enable regular visits to many villages rather than an occasional ship requiring a large jetty and deep water. And biannual dry docking 1,500 miles away.
The video shows the maiden voyage, the attached photo is the control panel of the 6kw electric motor. The story of the build is
here.
