Looking for love or hate. Give me your opinions on this design
Opinions are like... well, we've all got them. I'm not looking for that here.
I see that many very experienced sailors have glowing opinions of modern designs that define seaworthiness in a way I am unfamiliar with.
I thought you didn't want any opinions...
I'd suggest you find a living designer with a track record of drawing good all around boats, that develops designs with ease of construction and practical build strategies an amateur can accomplish in mind. It may sound simple but it is a short list.
Look at Dudley Dix's catalogue and contact him.
You will end up with a much better all around boat. You can hang prints of narrow (and questionable) focus clam crushers on the wall.
Vineet,
What is it you're trying to ascertain here?
Ignoring members is not a good way to make friends.
A longer boat will serve your purposes better BUT,
if you want to build your little boat then do it.
Who are we to tell you otherwise.
What is the proposed completion date,
or are you waiting on funding?
This boat comes in at 14,000 lbs?
What does this mean?
Does it mean when fully provisioned? Or does it mean just the bare boat and rig?
I suspect that the 35 footer's displacement number is just the boat with no provisions.
I also suspect that this number for the 26 footer includes the full provisioning.
But even if the two are the same, is the 35 footer really no bigger than the 26 footer?
I'd say the 35 footer is the bigger boat even if both the empty and loaded displacements of the two boats are the same.
The 35 footer probably has greater rigging loads on account of it likely having a larger Beam. It also likely requires a bigger anchor because it has greater bulk. It may need a bigger engine for the same reason.
Yeah, it has a greater potential speed speed than the heavy 26 footer. But, without an attentative crew, how likely is it to reach that speed?
A spinnaker may be better than a single Chinese lug, but it is a temperamental beast.
I have read numerous stories of a slower boat making a faster passage, because it is easier to manage, and thus ends up performing closer to its potential speed.
Because of its Chinese lug sail, reefing (and un-reefing) will be so easy that there will be far less temptation to carry either too much sail or too little.
Also, on the shorter boat, things will be less far away from one another.
And finally, the 35 footer was likely designed for short and moderate passages, which likely don't include ocean crossings.
The 26 footer is clearly designed for them.
The higher rigging loads must be a reflection of greater stability, which is generally considered a good thing.
The 36 footer may not need a bigger engine at all for similar speed, because to achieve the same sort of speeds the smaller boat will be operating very close to its hull speed where drag increases dramatically.
The 36 footer will be dramatically faster and therefore, all else being equal, do far less motoring for a similar passage time.
A typical 36 footer will be dramatically faster than an extremely heavy 26 foot junk rigged boat. Take, for example, an excellent heavy 25/26' long keeler like the Contessa 26, SCOD, Folkboat or Stella. Even fully equipped racing versions of these 25/26ers are about 15% slower than a typical conservative 36 footer like say a Sigma 36, C&C 35-2, Ericson 35-2, or Jeanneau Sunshine 36. The gap between a very well equipped and very well sailed boat on the one hand, and a poorly sailed boat with ancient gear, roller furlers and a bad bottom is normally far less than that. And then add in the fact that according to the Junk Rig Association itself, the junk is about 9% slower than the sloop and you're looking at the huge margin of 24% - and that's assuming that the designers of the Contessa, SCOD, Folkboat and Stella are complete incompetents who somehow managed to make their 25/26 footers slower than a 6 ton cruiser. Surely we should not hold designers like Holman and Nicholson in such utter contempt as that!
Put it this way - that's the same speed difference as there is between a Folkboat and a J/35, or between a J/24 and a Swan 56, J/125 or Farr 40. It'd be almost impossible to make up anything like that difference, no matter how much difference in attention the crew paid.
Sure, some people sometimes make faster passages in small boats, but a speed difference of way over 24% (after allowing for the fact that the Penny must be far slower than the lighter SCOD, Folkboat, Nich, Vertue etc) is not the sort of difference you can often make up.
With modern gear, a 36 footer can be very easy to manage. Nor does anyone actually seem to prove that a good modern rig is actually harder to handle than a junk rig. Something like my 36 can go from zero to 25 knots or so without reefing at all, because all you need to do is just pull on some backstay and ease the traveller and inhaul to flatten the rig. Reefing takes less than a minute, from the cockpit. And of course a decent 36'er could be sailed just under reefed mainsail and still sail a heavy JR 26' over the horizon quickly. You don't need a spinnaker to sail straight away from a heavy 26' junk rigger.
Who said a 36'er isn't designed for ocean passages?
You can safely assume it's lightship displacement, without anything. The sheated strip version, the Penny, is quoted at 10500lbs, so it's no wonder the Al version is 14000lbs, especially if they optimized for amateur construction with thicker plate for easier welding. About 40-50% of the quoted figure is ballast.
They explicitly compare the design with the Giles Vertue, and wooden Vertue's are reported at around 11000lbs, while the fiberglass ones are around 9000lbs. The Penny's are slightly bigger boats, beamier and taller (more headroom under a full flush deck).
[Do you mean initial stability? If so, I agree. But that's part of my point. The rigging will be bigger and more expensive to replace. Not a big thing, but it should be considered when making a fair comparison.]
[The engine size will most likely be chosen based on what's needed to power out of trouble, rather than what's needed to loaf around at a low S/L. We're talking about a production boat here, aren't we? Of course, the same is true for the 26 footer. Both will probably have engines big enough to push them an S/L of 1.34 against a considerable headwind. My assumption is that the smaller boat, although it will have the same displacement, will have less windage, especially since less of it sits above the WL.]
[Probably true, if the skipper is keen on arriving at a destination at a give time. Also, the bigger boat has a huge motoring advantage by having a longer WL. But if the skipper is not that keen on reaching a destination at a given time, the slower sailing and powering speed may not be that big of a handicap.]
[I don't mean to hold anyone in contempt. Certainly, these fellows are excellent designers. And their bigger creations certainly CAN vastly out perform the heavy junk rigged boat, especially if both are aggressively sailed. But if sailed casually? I have my doubts. I have read accounts of of ocean voyages extensively, and I have noticed that the heavy, smaller boats tend to punch above their weight in passage times. It seems almost no one goes more than 120 miles per day. And often it is less than that. I don't know why. My guess is that it is less work to sail the smaller boat harder than it is to sail the bigger boat nearly as hard. It also seems to me that a heavier boat can tolerate a small S/D better than a lighter one can. As for the junk rig being say 10% slower, does this mean on all points of sail? Or does it mean merley dead upwind and dead downwind? My personal experience is that sailing dead downwind is a misery (and potentially dangerous as well). And most ocean passages are not sailed upwind.]
[All this is great until something breaks. When I first started following accounts of ocean voyages, self-steering vanes were a new expensive technology. And break downs were frequent. The newer ones seem more reliable. But I have noticed that the more modern boats have been shifting towards auto-pilot systems. Nothing wrong with that. And they probably do a better job handling higher speeds. But it is just another piece of equipment to break down. And they need an electric power source, which can break down also. As for the modern rig being just as easy to handle, what do you mean? Do you mean with roller furling on all sails? Or do you mean with a roller furling jib and plain slab reefing for the main? Maybe you can reef your main in just one minute. Can you do it in a sudden squall at three in the morning, after you have already put a first reef? I know traditional rigs (including the junk rig) can be somewhat cumbersom compared to modern ones. After all, that yard has to be hauled aloft. But I think they are easier to repair, especially under primitive conditions. They can also tolerate less expensive materials, including sail cloth. This is especially true with the junk rig. And how long do the sails last on a modern boat (such as one that has a flat head main) ? And how much do they cost to replace?]
[I never said they weelren't. But I think we both can agree that most production boats are really designed for short to medium length passages, because that's where the real market is. This doesn't mean they can't make long passages. And many of them do. But often they are specifically reenforced for the purpose. I have seen several instances where bulkhead chain plates have been moved to the top sides, for example.]
In the comments above, I don't mean to disparage modern boats. But I do mean to point out that they can come with certain disadvantages which are not all that obvious. And that the tubby slow slug of a boat may actually be the better deal, once potential speed performance is not a top priority.
