Hi mass... I think all the power graphs (3 from TANSL, one from Ad Hoc and one from me) that models your hull is trying to do the same - predict the power/speed. I was worried that the bulges might add significant drag in his sim, that is why I drew a smoother, similar shape for TANSL to run. But I no longer think that is a significant issue? My smooth hull had more drag than yours in the end.
So, which prediction should you believe? Like I said, my numbers are only correlated to one other boat, which was very different to yours. Also I have not studied the formulas in the spreadsheet I use. Hence, I would not have put much trust in my numbers, but it was interesting to see that they weren't that far from Ad Hoc's numbers in the relevant speed range. Yes, my numbers take into account the rocker but WL shape and other shape factors are only approximate.
Like I alluded to, I would not be surprised if Ad Hoc has tested his method against many real boats - if it was me, I would go with his numbers.
I don't believe the hull-hull interference is going to be a very big deal, as mentioned by TANSL too.
I'm pretty sure a foil is a good idea, but I'm not able to model what effect it would have on speed.
I had one 6hp to one side of the 6m cat, and it had a shelf just above the propeller where I mounted two windsurfer fins. It helped a tiny bit on speed, but it was actually faster to take them off and ballast the bows.
These were the downfalls of my foil as I see it:
Too short span
Too shallow
Big lift discontinuity in the center where the engine strut was
Symmetric sections.
