HelmutSheina
Senior Member
- Joined
- Dec 25, 2025
- Posts
- 336
- Reaction score
- 118
- Location
- New South Wales
The only Port Sorell I'm aware of is on the Bass Strait coast of my home state of Bicrania; and thus this boat will be designed to handle a bit of rough.Just the 6 sheets of 6ply weigh 90 lbs at least, skin on frame as suggested would go close , the areas you intend to use the boat mean it will need airtight sections in case of swamping. The nesting suggestion halves the weight to the waters edge and is much closer to normal weight, rivetted or welded aluminium is also possible, good luck.
