Christopher Sandlin
New Member
- Joined
- Jan 31, 2026
- Posts
- Reaction score
- Location
- Puerto Rico
Greetings,
After spending some time with ChatGPT explaining the requirements needed it pushed out these specs. Of course it looks great on paper. I'm not qualified to determine if it's realistic.
Is this a reasonable spec for a rowboat design that could be built in ply/epoxy?
If so, is anyone so qualified interested in doing the design and build plans?
Thank you in advance.
Chris
1. Principal Dimensions & Performance Targets
Length Overall (LOA): 15' 11" (max from 16' ply)
Length Waterline (LWL): ~15' 2"
Beam Overall: 48" (1.22 m)
Beam at Waterline: 38–40"
Depth Midships: 16"
Freeboard (loaded): 9–11"
Draft (loaded @ 650–750 lb): 5.5–6.5"
Target Hull Weight: 75–90 lbs finished
Design Displacement:
• 650–750 lbs total
500 lbs people + gear
Primary Stability: Very high
Secondary Stability: High via flare
Seakeeping: Optimized for short-period Caribbean chop
2. Hull Form Description
Hull Type: Shallow-arch, soft-bilge rowing skiff / widened wherry hybrid
Sections:
• Soft U-shaped midship sections
• Slight V forward for wave entry
• Slightly flattened run aft for tracking + beach drag
• Flared topsides for secondary stability + spray control
Chines: Soft / radiused (not hard chine)
Rocker: Moderate fore & aft for maneuverability + surf handling
Bow:
• High flare
• Fine entry
• Reinforced stem for beach impact
Stern:
• Small reinforced transom
• Moderate rocker for following seas + landing
3. Structure & Materials
Bottom: 6mm marine ply
Sides: 6mm marine ply
Transom: 9mm marine ply
Frames: 9mm ply or laminated hardwood
Sheer Clamp: Laminated hardwood
Keel Batten: Hardwood or UHMW wear shoe
Fiberglass:
• Full exterior sheathing 6–10 oz cloth
• Extra glass on keel + bow + beach zones
• Heavy oarlock reinforcement pads
Finish:
• Epoxy sealed
• Durable marine paint (not bright varnish)
4. Frame Spacing & Structural Layout
Stations (approx):
• Frame spacing: 18–20"
• Total frames: 8–9 frames + transom + stem
Suggested Layout:
Station 0 — Transom
Station 1 — 20" forward
Station 2 — 40"
Station 3 — 60"
Station 4 — 80" (midship / rowing station)
Station 5 — 100"
Station 6 — 120"
Station 7 — 140"
Station 8 — 160" (stem)
Reinforced Areas:
• Rowing station bulkhead
• Oarlock frames
• Bow landing zone
• Stern grab/drag zone
5. Plywood Layout (Efficient Sheet Use)
Bottom Panels:
• (2) full 16' × 4' sheets scarfed or puzzle-jointed
• Split centerline bottom
Side Panels:
• (2) full 16' × 4' sheets each side (upper/lower if needed)
Frames/Transom:
• (2–3) additional 4' × 8' sheets
Total plywood estimate:
6–7 sheets marine ply per boat
6. Rowing Geometry
Seat Type: Fixed seat
Foot Brace: Adjustable
Oarlock Spread: 60–64"
Oar Length: 7'–8' recommended
Thwarts: Removable or fixed for rigidity
7. Rough Hydrostatic Estimates (Concept Level)
Based on similar hulls scaled:
Block Coefficient (Cb): ~0.42–0.46
Prismatic Coefficient (Cp): ~0.54–0.58
Midship Coefficient (Cm): ~0.85
Displacement @ 6" Draft: ~650–700 lbs
Waterplane Area: ~45–55 sq ft
Initial Stability (GMt): High
8. Beach Launch / Abuse Features
• UHMW or hardwood keel shoe
• Glassed bow stem pad
• Reinforced transom drag edge
• Internal handholds
• Non-skid floor paint
• Drain plug for rinsing
Chris
Depth Midships: 16"
• 650–750 lbs total
Sections:
Bow:
• High flare
• Fine entry
Stern:
Fiberglass:
Finish:
• Epoxy sealed
Stations (approx):
Suggested Layout:
Station 0 — Transom
Station 2 — 40"
Station 3 — 60"
Station 5 — 100"
Station 6 — 120"
Station 7 — 140"
Reinforced Areas:
• Oarlock frames
• Bow landing zone
Bottom Panels:
Side Panels:
Frames/Transom:
6. Rowing Geometry
