skaraborgcraft
Senior Member
- Joined
- Dec 2, 2020
- Posts
- 985
- Reaction score
- 318
- Location
- sweden
Note: This feature may not be available in some browsers.
I saw a catamaran with a design that does something like what you describe, could something like that not be used for the gyrocopter, from the upper deck? With a winch it shouldn't be that hard since it has wheels.Wet or dry storage dock like this.
Or, like a stern trawler, you could have a semi open stern with a fold down ramp/ closure. If you can put the submersible onto a docking sled, you only might need a winch, rather than a crane.
I dont know how or where you would sling an 800kg load on a catamaran without a detrimental effect.
Interesting that the displacement is shown as 18500kg, with a payload of 6000kg........but the fuel and water add up to around 7600kg itself.
As an example, twin 350 (yanmars as example) would weigh in around 870kg, twin 80s 458kg, would give you an extra 400+kg allowance, but that is still another 400kg plus the lifting system on two fine ended hulls. No doubt if you know the weights you want to accommodate, the hulls could be refined in the aft end to allow extra weight and loading. The gyro is not what i would see as the big issue, its the 800kg lump of submersible.
Why do you perceive that a cat is better for you purpose than a monohull?
I guess anything below the point at which I need to have crew, though I'm guessing that's going to vary between ship designs and equipment. I suppose a hard limit would be around 80 ft.
80 ft is a big boat for a couple. Lot of wind surface area and a pretty good little sprint to grab lines on a blustery day. Have short handed some boats in that length when transporting them. Doable but a brisk learning curve.
We found a boat we liked about ten years ago, wife took a pic of it and we used Google image search for similar images. Found an old post on the original build, tracked down the builder and was linked to the naval architect involved after some internet sleuthing.
I'd probably pull up pics of boats you like, then do an image search of all similar vessels. That's likely to lead you to a builder or an architect name. From there it's like rolling the dice to hope they are still alive and active....
This looks pretty cool if it's possible to fit the toys and enclose the flybridge, but I don't see any details about propulsion or efficiency. Is that usually part of the paid study plans?
Oh wow this is promising. Thank you very much!semi displacement catamarans — Jutson Marine Design https://www.powercatamaran.ca/semi-displacement-catamarans
The 40 footer is running around up here. It looks like it runs pretty efficient, and the add has a computer version similar to what your thinking.
The pics have it fit out spartan as a 20 year old you tuber fits out their "conversion van".
...That's what we've been picking up, which led us to search for narrow long vessels like the FPB. We want to see what compromises it would lead to for a multihull.
