Actually, yes!......
A propeller approaching the surface will generate a thrust vector directed slightly upwards (and often to the side as well), unless specifically designed for a downforce. Maximum vertical composant occurs at about 50% submergence, depending on blade design. This was "discovered" in the racing community and led to the evolution of the "propriders". Here the vertical force is strong enough to balance the hull, which consequently is supported by three points; the two sponsons and the prop.
